Try this code using the hd44780 library. You will need to install the library per the instructions in my first reply. This code works fine with my Uno and a 2004 LCD. I prints all the stuff in setup() and sends OKAY, Also, IN LOOP to serial monitor. I made it send IN LOOP only once so it does not spam serial monitor and also it will erase line one and print the current value of millis() once per second.
function:You should now see your I2C LCD2004 display "Hello,world!","IIC/I2C LCD2004"
"20 cols, 4 rows","www.sunfounder.com"
//Email:service@sunfounder.com
//Website:www.sunfounder.com
// include the library code
#include <Wire.h>
//#include <LiquidCrystal_I2C.h>
#include <hd44780.h> // main hd44780 header
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
//LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
hd44780_I2Cexp lcd;
bool loopFlag = false;
Serial.println("OKAY");
delay(2000);
//lcd.init(); //initialize the lcd
lcd.begin(20, 4);
lcd.backlight(); //open the backlight
lcd.setCursor ( 0, 0 ); // go to the top left corner
lcd.print(" Hello,world! "); // write this string on the top row
lcd.setCursor ( 0, 1 ); // go to the 2nd row
lcd.print(" IIC/I2C LCD2004 "); // pad string with spaces for centering
lcd.setCursor ( 0, 2 ); // go to the third row
lcd.print(" 20 cols, 4 rows "); // pad with spaces for centering
lcd.setCursor ( 0, 3 ); // go to the fourth row
lcd.print(" www.sunfounder.com ");
Serial.println("Also");
if (loopFlag == false)
Serial.println("IN LOOP");
delay(2000);
loopFlag = true;
static unsigned long timer = 0;
unsigned long interval = 1000;
if (millis() - timer >= interval)
timer = millis();
lcd.setCursor(0,0);
lcd.print(" "); // clear old data
lcd.setCursor(3,0);
lcd.print("millis = ");
lcd.print(millis());
If all that you see is still just blocks, try adjusting the contrast.
