LCD compiling error
How to fix this error
LCD_test_2:16: error: 'prog_uint8_t' does not name a type
const prog_uint8_t *ptr; // pointer to font table
LCD_test_2:98: error: 'prog_uint8_t' does not name a type
void bitmap(uint8_t x0, uint8_t y0, uint8_t width, uint8_t height, const prog_uint8_t data[]);
exit status 1
#include <Arduino.h>
#include <avr/pgmspace.h>
#include <Print.h>
// Enumeration for specifying drawing modes
enum PixelMode
  PixelClear = 0,    // clear the pixel(s)
  PixelSet = 1,      // set the pixel(s)
  PixelFlip = 2      // invert the pixel(s)
// Struct for describing a font table, always held in PROGMEM
struct LcdFont
  uint8_t startCharacter;    // character code (e.g. ASCII) of the first character in the font
  uint8_t endCharacter;      // character code of the last character in the font
  uint8_t height;            // row height in pixels - only this number of pixels will be fetched and drawn - maximum 16 in this version of the sofware
  uint8_t width;             // max character width in pixels (the font table contains this number of bytes or words per character, plus 1 for the active width)
// Class for driving 128x64 graphical LCD fitted wirth ST7920 controller
// This drives the GLCD in serial mode so that it needs just 2 pins.
// Preferably, we use SPI to do the comms.
// Derive the LCD class from the Print class so that we can print stuff to it in alpha mode
class Lcd7920 : public Print
public:
  // Construct a GLCD driver.
  //  cPin = clock pin (connects to E pin of ST7920)
  //  dPin = data pin (connects to R/W pin of ST7920)
  // useSpi = true to use hardware SPI. If true then cPin must correspond to SCLK, dPin must correspond to MOSI, and SS must be configured as an output.
  Lcd7920(uint8_t cPin, uint8_t dPin, bool useSpi);    // constructor
  // Write a single character in the current font. Called by the 'print' functions. Works in both graphic and alphanumeric mode.
  // If in graphic mode, a call to setFont must have been made before calling this.
  //  c = character to write
  // Returns the number of characters written (1 if we wrote it, 0 otherwise)
  virtual size_t write(uint8_t c);                 // write a character
  // Initialize the display. Call this in setup(). If using graphics mode, also call setFont to select initial text font.
  //  gmode = true to use graphics mode, false to use ST7920 alphanumeric mode.
  void begin(bool gmode);
  // Select the font to use for subsequent calls to write() in graphics mode. Must be called before calling write() in graphics mode.
  //  newFont = pointer to font descriptor in PROGMEM
  void setFont(const PROGMEM LcdFont *newFont);
  // Select normal or inverted text (only works in graphics mode)
  void textInvert(bool b);
  // Clear the display. Works in both graphic and alphanumeric mode. Also selects non-inverted text.
  void clear();
  // Set the cursor position
  //  r = row. In alphanumeric mode this is text row number.
  //           In graphics mode it is the number of pixels from the top of the display to the top of the character.
  //  c = column. In alphanumeric mode this must be even (S7920 restriction becasue the characters are double width).
  //              In graphics ode this is the number of pixels from the left hand edge of the display and the left hand edge of the character.
  void setCursor(uint8_t r, uint8_t c);        // 'c' in alpha mode, should be an even column number
  // Flush the display buffer to the display. In graphics mode, calls to write, setPixel, line and circle will not be committed to the display until this is called.
  void flush();
  // Set, clear or invert a pixel
  //  x = x-coordinate of the pixel, measured from left hand edge of the display
  //  y = y-coordinate of the pixel, measured down from the top of the display
  //  mode = whether we want to set, clear or invert the pixel
  void setPixel(uint8_t x, uint8_t y, PixelMode mode);
  // Read a pixel. Returns true if the pixel is set, false if it is clear.
  bool readPixel(uint8_t x, uint8_t y);
  // Draw a line.
  //  x0 = x-coordinate of one end of the line, measured from left hand edge of the display
  //  y0 = y-coordinate of one end of the line, measured down from the top of the display
  //  x1, y1 = coordinates of the other end od the line
  //  mode = whether we want to set, clear or invert each pixel
  void line(uint8_t x0, uint8_t y0, uint8_t x1, uint8_t y1, PixelMode mode);
  // Draw a circle
  //  x0 = x-coordinate of the centre, measured from left hand edge of the display
  //  y0 = y-coordinate of the centre, measured down from the top of the display
  //  redius = radius of the circle in pixels
  void circle(uint8_t x0, uint8_t y0, uint8_t radius, PixelMode mode);
  // Draw a bitmap
  //  x0 = x-coordinate of the top left, measured from left hand edge of the display. Currently, must be a multiple of 8.
  //  y0 = y-coordinate of the top left, measured down from the top of the display
  // width = width of bitmap in pixels. Currently, must be a multiple of 8.
  // rows = height of bitmap in pixels
  // data = bitmap image in PROGMEM, must be ((width/8) * rows) bytes long
private:
  bool gfxMode;
  bool extendedMode;
  bool useSpi;
  bool textInverted;
  uint8_t clockPin, dataPin;
  uint16_t lastCharColData;                   // data for the last non-space column, used for kerning
  uint8_t row, column;
  uint8_t startRow, startCol, endRow, endCol; // coordinates of the dirty rectangle
  uint8_t image[(128 * 64)/8];                // image buffer, 1K in size (= half the RAM of the Uno)
  const PROGMEM struct LcdFont *currentFont;  // pointer to descriptor for current font
  void sendLcdCommand(uint8_t command);
  void sendLcdData(uint8_t data);
  void sendLcd(uint8_t data1, uint8_t data2);
  void sendLcdSlow(uint8_t data);
  void commandDelay();
  void setGraphicsAddress(unsigned int r, unsigned int c);
  void ensureBasicMode();
  void ensureExtendedMode();
I have a program to which I need to add LCD display, this one is for LCD128x64 but can be LCD16X2. Probably the second one will be easier to implement.
Not if you can't read and google.
