And then define those pins in the code with the following line:
LiquidCrystal lcd(2,4,5,6,7,8);
as soon as the sketch uploads the arduino freezes, if i run the sketch with no lcd attached then it works fine, as soon as I attach it then it freezes.
It will run a sketch fine if i dont use the LCD in the code, so it doesnt seem to be a physical problem
This part is correct. The tutorial doesn't explain how this works, it's buried here LiquidCrystal - Arduino Reference. By the way, do you see why the use of code tags is important to correctly present your code?
In order to have any chance at diagnosing your problem we need more information. This would include not only a photo of your setup but the complete sketch as well.
Don , I spent ages reading past posts about this sort of thing from you yesterday, it seems that wherever there are LCD problems that Don is there to save the day.
Anyway, long story short, i hadnt connected the RW pin a quick wire to ground and VIOLA what a suprise, things seem to work as they should, or at least i have a sketch that doesnt freeze and there is writing on the screen thats refreshing itself,
that seems to be a good start,
thanks to everyone for making me draw a schem, I didnt want to look like a total numpty so obviously checked everything twice whilst drawing it ,
well it worked briefly and then went crazy again, haha
I found that when I pressed a switch that connected D10 to ground that everything went well, I have no clue why , then I looked and there was a solder blob on between the tracks of 10 and 11,
now more crazyness, so I have the whole affair under a magnifying glass to see if there are any more rogue solder blobs or any dry joints,
Well after a lot of poking prodding resoldering and more resoldering, I hav eprogressed
I found that my push to make switches were installed with a 90 degree offset, meaning that I had 10 11 and 12 connected to ground all the time, I dont know why this would stop the sketch running, but I have removed the switches and it now runs,
I also had a dippy IDE cable on the FTDI powering it all , which, with the slightest of movement would reset power,
So with those hurdles behind me, and the HELLO WORLD sketch running "smoothly" i have the next question ,
Why can I only see characters 0 -7 on the lcd on rows 0 and 1? I have the LCD object defined as 16,2 but alas no luck seeing the characters after column 7.
is it possible that I have it in 8 bit mode and only have the four data wires connected?? or would that just not show anything onscreen?
Are they the PCB-mount tactile type? If so, someone posted a tip about them a while - if you wire to opposite corners, you are guaranteed to not have a short
This sounds like it may be a problem with the connections between the display and the pc board. Do a search on this site for 'zebra' (I'm not kidding) to find some topics concerning this.
In this case you would see a single row of blocks on the screen.
It's not likely to be software related, but just in case you should try writing data to every memory location in the LCD controller.
#include <LiquidCrystal.h>
//LiquidCrystal lcd(rs,en,d4,d5,d6,d7);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // put your pin numbers here
lcd.begin(20, 4); // put your LCD parameters here
for (char i=47; i<127; i++) // send 80 consecutive displayable characters to the LCD
lcd.print(i);
delay(100); // this delay allows you to observe the addressing sequence
Are they the PCB-mount tactile type? If so, someone posted a tip about them a while - if you wire to opposite corners, you are guaranteed to not have a short.
That's a great idea for loose switches on a workbench or when designing a pc board. It will also work if you can somehow mount the switch over the gap in the middle of a solderless breadboard (but I don't think they are large enough to bridge the gap). If you mount them on either side of the gap they still have to be oriented properly.
After a lot of messing around I took everything off the board except the lcd and th e arduino chip, resonator and caps.
It started to randomly reset after a length of time, normally under 30 seconds,
i tried to reflash the bootloader just incase and couldnt, although could always load sketches,
in the end it has ended up in a box until my fury subsides
I will try the code to write to each memory block later, I want to know if the screen is still working before I continue,
