Hello! I know the title isn't clear but I didn't know how to phrase it properly. Basically, I'm using this code that I made to display a cursor on screen. Only problem is that whenever you hover your cursor over an item on the LCD, that item gets replaced with your cursor (intended) but when you remove your cursor, the item stays as a cursor (not intended). I know why it's leaving behind a cursor and I know how to solve it if I need to, but I was wondering if it's possible to dynamically save everything on screen into an array or list and then use that to replace what was there after the cursor leaves. Is it even possible with arrays? It doesn't need to but that's the only thing I can think of. Here's the code:
#include <LiquidCrystal.h>
#define joyX A0
#define joyY A1
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
const int buzzer = 8;
const int button = 7;
const int led = 6;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//Custom Characters
byte keyWhite[] = {
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte keyWhiteContinued[] = {
B11111,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11111
byte keyBlack[] = {
B11111,
B10001,
B10001,
B10001,
B10001,
B10001,
B10001,
B11111
byte keyBlackContinued[] = {
B11111,
B10101,
B10101,
B10101,
B10101,
B10101,
B10101,
B11111
byte blank[] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
byte settings[] = {
B00000,
B10101,
B01110,
B11011,
B01110,
B10101,
B00000,
B00000
byte settingsSelected[] = {
B00000,
B10101,
B01110,
B11011,
B01110,
B10101,
B00000,
B11111
byte selectionBox[] = {
B11011,
B10001,
B00000,
B10001,
B10001,
B00000,
B10001,
B11011
float xValue = 0;
float yValue = 0;
int buttonState = 0;
int prevButtonState = 0;
int selectionX = 0;
int selectionY = 0;
int prevselectionX = 0;
int prevselectionY = 0;
int octaveNum = 1;
int scroll = 0;
int bpm = 120;
lcd.createChar(0, keyWhite);
lcd.createChar(1, keyBlack);
lcd.createChar(2, keyWhiteContinued);
lcd.createChar(3, keyBlackContinued);
lcd.createChar(5, blank);
lcd.createChar(6, settings);
lcd.createChar(7, selectionBox);
pinMode(buzzer, OUTPUT);
pinMode(led, OUTPUT);
pinMode(button, INPUT);
lcd.begin(16, 2);
tone(buzzer, 440, 100);
PrintWhite();
PrintBlack();
lcd.setCursor(15, 0);
lcd.write(6);
lcd.setCursor(selectionX, selectionY);
lcd.write(7);
lcd.setCursor(15, 1);
lcd.print(octaveNum);
xValue = analogRead(joyX) / 1023.0 * 2 - 1;
yValue = analogRead(joyY) / 1023.0 * 2 - 1;
buttonState = digitalRead(button);
//LEFT AND RIGHT
if (xValue > 0.9 || xValue < -0.9)
if (xValue < -0.9) //Right
selectionX++;
if (selectionX > 15 && !(octaveNum > 4))
selectionX = 0;
octaveNum++;
if (xValue > 0.9) //Left
selectionX--;
if (selectionX < 0 && !(octaveNum < 2))
selectionX = 15;
octaveNum--;
lcd.write(7);
delay(250);
//Up and Down
if (yValue > 0.9 || yValue < -0.9)
if (yValue < -0.9 && !(scroll == 0)) //Down
selectionY++;
if (selectionY > 1)
selectionY = 0;
scroll--;
if (yValue > 0.9) //Up
selectionY--;
if (selectionY < 0)
selectionY = 1;
scroll++;
lcd.write(7);
delay(250);
if (buttonState != prevButtonState)
if (buttonState == HIGH)
AddNote(selectionX - 2, octaveNum, (600 / bpm) * 100);
delay(250);
prevButtonState = buttonState;
void PrintWhite() {
lcd.setCursor(2,1);
lcd.write(byte(0));
lcd.setCursor(4,1);
lcd.write(byte(0));
lcd.setCursor(6,1);
lcd.write(byte(0));
lcd.setCursor(7,1);
lcd.write(byte(0));
lcd.setCursor(9,1);
lcd.write(byte(0));
lcd.setCursor(11,1);
lcd.write(byte(0));
lcd.setCursor(13,1);
lcd.write(byte(0));
void PrintBlack() {
lcd.setCursor(3,1);
lcd.write(byte(1));
lcd.setCursor(5,1);
lcd.write(byte(1));
lcd.setCursor(8,1);
lcd.write(byte(1));
lcd.setCursor(10,1);
lcd.write(byte(1));
lcd.setCursor(12,1);
lcd.write(byte(1));
void AddNote(int key, int oct, int length) {
if (oct == 1)
if (key == 0)
tone(buzzer, 65.40639, length);
if (key == 1)
tone(buzzer, 69.29566, length);
if (key == 2)
tone(buzzer, 73.41619, length);
if (key == 3)
tone(buzzer, 77.78175, length);
if (key == 4)
tone(buzzer, 82.40689, length);
if (key == 5)
tone(buzzer, 87.30706, length);
if (key == 6)
tone(buzzer, 92.49861, length);
if (key == 7)
tone(buzzer, 97.99886, length);
if (key == 8)
tone(buzzer, 103.8262, length);
if (key == 9)
tone(buzzer, 110.0000, length);
if (key == 10)
tone(buzzer, 116.5409, length);
if (key == 11)
tone(buzzer, 123.4708, length);
if (oct == 2)
if (key == 0)
tone(buzzer, 130.8128, length);
if (key == 1)
tone(buzzer, 138.5913, length);
if (key == 2)
tone(buzzer, 146.8324, length);
if (key == 3)
tone(buzzer, 155.5635, length);
if (key == 4)
tone(buzzer, 164.8138, length);
if (key == 5)
tone(buzzer, 174.6141, length);
if (key == 6)
tone(buzzer, 184.9972, length);
if (key == 7)
tone(buzzer, 195.9977, length);
if (key == 8)
tone(buzzer, 207.6523, length);
if (key == 9)
tone(buzzer, 220.0000, length);
if (key == 10)
tone(buzzer, 233.0819, length);
if (key == 11)
tone(buzzer, 246.9417, length);
if (oct == 3)
if (key == 0)
tone(buzzer, 261.6256, length);
if (key == 1)
tone(buzzer, 277.1826, length);
if (key == 2)
tone(buzzer, 293.6648, length);
if (key == 3)
tone(buzzer, 311.1270, length);
if (key == 4)
tone(buzzer, 329.6276, length);
if (key == 5)
tone(buzzer, 349.2282, length);
if (key == 6)
tone(buzzer, 369.9944, length);
if (key == 7)
tone(buzzer, 391.9954, length);
if (key == 8)
tone(buzzer, 415.3047, length);
if (key == 9)
tone(buzzer, 440.0000, length);
if (key == 10)
tone(buzzer, 466.1638, length);
if (key == 11)
tone(buzzer, 493.8833, length);
if (oct == 4)
if (key == 0)
tone(buzzer, 523.2511, length);
if (key == 1)
tone(buzzer, 554.3653, length);
if (key == 2)
tone(buzzer, 587.3295, length);
if (key == 3)
tone(buzzer, 622.2540, length);
if (key == 4)
tone(buzzer, 659.2551, length);
if (key == 5)
tone(buzzer, 698.4565, length);
if (key == 6)
tone(buzzer, 739.9888, length);
if (key == 7)
tone(buzzer, 783.9909, length);
if (key == 8)
tone(buzzer, 830.6094, length);
if (key == 9)
tone(buzzer, 880.0000, length);
if (key == 10)
tone(buzzer, 932.3275, length);
if (key == 11)
tone(buzzer, 987.7666, length);
if (oct == 5)
if (key == 0)
tone(buzzer, 1046.502, length);
if (key == 1)
tone(buzzer, 1108.731, length);
if (key == 2)
tone(buzzer, 1174.659, length);
if (key == 3)
tone(buzzer, 1244.508, length);
if (key == 4)
tone(buzzer, 1318.510, length);
if (key == 5)
tone(buzzer, 1396.913, length);
if (key == 6)
tone(buzzer, 1479.978, length);
if (key == 7)
tone(buzzer, 1567.982, length);
if (key == 8)
tone(buzzer, 1661.219, length);
if (key == 9)
tone(buzzer, 1760.000, length);
if (key == 10)
tone(buzzer, 1864.655, length);
if (key == 11)
tone(buzzer, 1975.533, length);
