LCD + DHT22 Help
Hi there-
I’m new to arduino, and programming/electronics in general. I received an arduino and a seeedstudio starter kit along with some various sensors as a gift a couple months ago, and I’ve been tinkering with it since.
Anyways, I’ve been trying to make a temperature and humidity gauge using the DHT22 sensor and 16 x 2 LCD display. Here is my code:
#include <SerialLCD.h>
#include <SoftwareSerial.h>
#include "DHT.h"
#define DHTPIN A0
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
SerialLCD slcd(11,12);
int t=0;
int h=0;
  slcd.begin();
  slcd.backlight();
  float h = dht.readHumidity();
  float t = ((dht.readTemperature()*1.8)+32);
  if (isnan(t) || isnan(h))
        Serial.println("Failed to read from DHT");
        Serial.print("Humidity: ");
        Serial.print(h);
        Serial.print(" %\t");
        Serial.print("Temperature: ");
        Serial.print(t);
        Serial.println(" *F");
  slcd.home();
  slcd.print(" TEMP: ");
  slcd.print(t);
  slcd.setCursor(0,1);
  slcd.print("HMDTY: ");
  slcd.print(h);
And here is my problem, the LCD does not display the sensor readings, just random characters:
https://drive.google.com/file/d/0B1Kkf4HgZKj4MkVTd2d6Qm5qRVE/edit?usp=sharing
I can tell the problem is not the sensor, when I check the serial monitor i get good readings:
https://drive.google.com/file/d/0B1Kkf4HgZKj4dXhiWFhjLUdEM0U/edit?usp=sharing
I’m not sure if this would be useful, but here are the wiki’s for the sensor and the display:
http://www.seeedstudio.com/wiki/index.php?title=Grove_-Serial_LCD_V1.0
http://www.seeedstudio.com/wiki/Grove
-_Temperature_and_Humidity_Sensor_Pro
I was hoping someone could point in the right direction to fix it. Like I said, I’m pretty new to this, I have a feeling I’m missing something basic, but this problem has stumped me for awhile now.
Thanks-
Trey Chaffin
And if you try the LCD in a simple "hello world" sketch? does it fails too?
No, I've gone through all the tutorial sketches that came with the LCD, they all work fine. It's just not display the sensor readings correctly on the LCD. When I check the serial monitor, which I have programmed to show the sensor readings, it shows them correctly. :P
slcd.begin();
maybe you need to set the baud rate of slcd explicitly?
slcd.begin(9600);
