Hello there . I bought LCD display , connected it to ramps 1.4 and now I´m not sure how to control it and print something on it .
Thank you for any advice.
There is very likely a library for the particular display you have, with examples to help get you started.
Do you have the RepRapDiscount Full Graphic Smart Controller with the adapter board and 2 flat cables for the Ramps 1.4 shield?
Are you trying to set it up to use with Marlin or do you want to use it "stand alone"?
I have display with two cables and i want to connect it to the ramps and display rotations of the motor. But I don't know a code that will display something on display
Thanks
See also:
what lcd. you mean char ones,nokia ones,shield ones,ST7789 ones,ST7735 ones,Graphics lcds,7 segment lcd/leds)
thanks a lot
reprapDiscount smart graphic controller
Can you share a photo pls
