Lcd display(2,16), Arduino game. problem with if sentences.
Hi
I have a problem when it comes to if sentences.
game works so that a buzzer will make a sound and when the sound is finished, there are two buttons (indicating each player). first person to press will get a point.
as you can see in the code, there will be a score on a lcd screen.
My problem:
if a player presses when the sound beep, he will be punished by minus point. I've tried with another if sentences and put the state at a higher value, but the problem is that it then skips one the "if sentences" so it only gets registered minus points.
Appendix 1 only positive score
Appendix 2 with minus points, but the score only goes towards minus.
anyone have a suggestion on how I can solve the problem?
opgave_1A_B_D_innlevering.ino (2.2 KB)
only_minus_points_.ino (2.44 KB)
this post is in project guidance. should be in programming questions
make sure the IF statements for each buzzer are not nested.
you have at least 4 break points, before the sound and the global time of the end of the sound
I dont see any if statements that are nested?!..
did not quite understand what you meant by that last thing you wrote, but have connected it up and the buzzer works properly.
