Lcd display not showing half of the text
#include <SPI.h>
#include <MFRC522.h>
#include <Servo.h>
#define SERVO_PIN 2
Servo myservo;
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
LiquidCrystal_I2C lcd(0x27, 16, 2);
  SPI.begin();
  lcd.init();
  lcd.backlight();
  mfrc522.PCD_Init();
Serial.println("Arduino RFID door lock");
mfrc522.PCD_DumpVersionToSerial();
  myservo.attach(SERVO_PIN);
opendoor();
void opendoor(){
  lcd.setCursor(0,0);
  lcd.print("Welcome: Guest");
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Door closes in");
    lcd.setCursor(0,1);
    lcd.print("5");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("4");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("3");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("2");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("1");
    lcd.clear();
    myservo.write( 0 );
  void jordan(){
  lcd.setCursor(0,0);
  lcd.print("Welcome: Jordan");
    myservo.write( 380 );
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("5");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("4");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("3");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("2");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("1");
    lcd.clear();
    myservo.write( 0 );
  void savio(){
  lcd.setCursor(0,0);
  lcd.print("Welcome: Savio");
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("5");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("4");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("3");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("2");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("1");
    lcd.clear();
    myservo.write( 0 );
  void jill(){
  lcd.setCursor(0,0);
  lcd.print("Welcome: Jill");
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("5");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("4");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("3");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("2");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("1");
    lcd.clear();
    myservo.write( 0 );
void sophia(){
  lcd.setCursor(0,0);
  lcd.print("Welcome: Sophia");
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("5");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("4");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("3");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("2");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("1");
    lcd.clear();
    myservo.write( 0 );
void loop(){
  //Look for new cards
  if ( !mfrc522.PICC_IsNewCardPresent() ){
    return;
  //Select one of the cards
  if ( !mfrc522.PICC_ReadCardSerial() ) {
    return;
  Serial.print("UID tag :");
  String content= "";
  byte letter;
  for( byte i = 0; i < mfrc522.uid.size; i++ ){
    Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
     Serial.print(mfrc522.uid.uidByte[i], HEX);
     content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
     content.concat(String(mfrc522.uid.uidByte[i], HEX));
  content.toUpperCase();
  Serial.println("UID tag :'" + content + "'");
  if ( content == "D4-73-CA-2A" || "D7-75-2A-7B" || "97-15-35-7B" || "D7-2C-36-7B" || "F7-F4-29-7B" || "67-72-39-7B" || "D7-7A-2C-7B" || "27-17-27-7B" || "F7-DB-37-7B" ){
    Serial.println("Guest");
   delay(300);
    opendoor();
    Serial.println("jordan");
   delay(300);
    jordan();
    Serial.println("sophia");
    Serial.println(content);
   delay(300);
    sophia();
  }if ( content == "D4-73-CA-2A" || "D7-75-2A-7B" || "97-15-35-7B" || "D7-2C-36-7B" || "F7-F4-29-7B" || "67-72-39-7B" || "D7-7A-2C-7B" || "27-17-27-7B" || "F7-DB-37-7B" ){
    Serial.println("jill");
   delay(300);
    jill();
    Serial.println("savio");
   delay(300);
    savio();
@arduinodeveloper99, your topic has been moved to a more suitable location on the forum.
I'm quite sure that this issue has been reported a couple of times, did you do a search?
Nothing matches my problem
Try this search.
If that is no help, adjust the contrast and post a better photos of the display. I cannot see the display very well in the video.
Post a couple of photos directly into the discussion thread.
What do you mean by half of the text?
displays one line instead of two?
displays characters that are cutoff halfway on each line.
displays characters halfway across the screen?
@Paul_B 's suggestion is a good one. :+1:
Please do not go back and add information to you first post.
Make a new post for your video.
Thanks... Tom... :smiley: :+1: :australia:
Remove all those LCD clear statements, the fact that you are writing a single digit number over the top of the previous, does not need the clear statement.
Your code actually writes the digit, then clears it ,then waits 1000ms display time, BUT you have cleared it previously with the clear statement.
It is on the screen for too short a time to see.
Tom.... :smiley: :+1: :coffee: :australia:
i didnt quite get it can you please edit the code and send it to me
I have edited your "sophia" function, you can shorten the code with a for loop.
void sophia(){
  lcd.setCursor(0,0);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("5");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("4");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("3");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("2");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("1");
    lcd.clear();
    myservo.write( 0 );
This will get you back on track, your other functions will need similar editing.
Tom... :smiley: :+1: :coffee: :australia:
thanks!!!
