LCD display showing strange symbols
Hi, I've been working for a couple days on a project to make code that can translate button presses in Morse code into letters, then show them on my LCD display.
I first tried this on a physical board, but I wasn't sure if it was a hardware issue, so I did it on a virtual one as well and got the exact same response.
Please let me know if there's anything I can improve upon or do to have the LCD show the blank screen on boot-up.
Here is a link to the virtual project, it is exactly the same as my physical setup:
https://wokwi.com/projects/385643983515875329
Also, feel free to disregard the comments, they are just helpful for me.
          lcd.write("?");
For a single character with write(), use single quotes
          lcd.write('?');
or use print()
          lcd.print("?");
Also, I don't think the simulation will ever work. You have the button input pin mode set to INPUT_PULLUP, and the button wired to 5 volts, there is no way the input could ever be LOW.
Thank you for the helpful advice. How could I rewire the button using INPUT_PULLUP so that it would work?
Wire the button from input to GND. digitalRead() will return LOW when the button is pushed.
It looks like that has done something, now the LCD shows this screen when the code runs:
