I am using this LCD display, http://www.adafruit.com/products/715 with a Arduino Uno Ethernet board. It also has an RFID reader (http://www.adafruit.com/products/364) but I haven’t really implemented the RFID yet.
Anyways, everything works pretty good so far. I am using this to create a timeclock and I created a restful API and that is what I am coding against. Anyways, the API I am dealing with an the moment returns the current time in the format hh:mm<am|pm>. So, I got that working, but what happens is that I get the time, and when I try to write it out to the LCD the character directly in front of the time is strange. Anyways, here is the code - please note that there is a few variables that aren’t used but that’s cause they’re is another setup that has the rest of the hardware implemented and I’m kind of merging the two.
// include the library code:
#include <Wire.h>
#include <SPI.h>
#include <Ethernet.h>
#include <Adafruit_PN532.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// Param Order: SCK, MISO, MOSI, SSEL
Adafruit_PN532 nfc(4, 5, 3, 2);
char* lcdText[] = {"", ""};
char* current_time = "GET /timeclock/current_time HTTP/1.1";
char* employee_api = "GET /timeclock/employee/rx/xyz HTTP/1.1";
char* payperiod_api = "GET /timeclock/payperiod/tx/xyz HTTP/1.1";
char response_used[512];
char* action;
int crlf = 0;
int char_int = 0;
int main_loop = 0;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0xB9, 0xF0 };
EthernetClient client;
void writeToLCD(char* text1 = "", char* text2 = "") {
if (lcdText[0] != text1 || lcdText[1] != text2) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(text1);
lcd.setCursor(0,1);
lcd.print(text2);
Serial.print("Text: "); Serial.println(text2);
lcdText[0] = text1;
lcdText[1] = text2;
lcd.setCursor(0,0);
uint32_t ChipVersion;
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
nfc.begin();
ChipVersion = nfc.getFirmwareVersion();
if (Ethernet.begin(mac) == 0) {
writeToLCD(" Ethernet", " Failed");
Serial.println(Ethernet.localIP());
write_request(current_time);
action = "current_time";
lcd.setCursor(0,0);
if (!ChipVersion) {
writeToLCD("RFID Error", "");
writeToLCD("Company Name", "Initializing");
nfc.SAMConfig();
void loop(void) {
lcd.noBlink();
main_loop++;
if (main_loop == 360) {
main_loop = 0;
if (action != "current_time") {
main_loop = 359;
while (client.available()) {
char c = client.read();
if (c == '\r' || c == '\n') {
crlf++;
if (crlf != 4) {
crlf = 0;
if (crlf == 4) {
response_used[char_int] = c;
char_int++;
if (!client.connected()) {
client.stop();
writeToLCD("Company Name", response_used);
} //End loop
Output of Serial Monitor:
192.168.150.117
Text: Initializing
Text:
9:00am
Output Of LCD:
['C', 'o', 'm', 'p', 'a', 'n', 'y', ' ', 'n', 'a', 'm', 'e', '', '', '', '']
['[]', '9', ':', '0', '0', 'a', 'm', '', '', '', '', '', '', '', '', '']
So basically that [] is the part I am trying to get rid of and I’m not 100% sure why it’s there… Anyways, thanks!
