hello guys
how can i display a time in .1 secounds ?
i know how to display seconds (mills/1000)
but how do i get that 0. seconds ?
hello guys
Try
millis()/1000.0
okay i will give that a try
if i dont find a fix i will draw a dot with a pen on the display
you can print it with xxx.print('.'); where xxx is either Serial or lcd.
i need to print unsigned ling RelayMillisDelay = 3000;
now i print it like this:
lcd.print (RelayMillisDelay / 1000);
then the value is 3s on the display but i need 3.0
and if the value is 3100 mills it should be 3.1 s
lcd.print (RelayMillisDelay / 1000.0, 1);
Hello @domsn123 - When I want to have the decimal points align, I use zeroes ("0") or spaces (" ") on the front of numbers (and with decimal values), I make functions called "zeroPad()" or "spacePad()"... it looks like this...
int val1 = 255;
int val2 = 42;
float val3 = 0.15;
Serial.print("ZeroPad");
Serial.print("\t\t");
Serial.println("SpacePad");
zeroPad(val1);
spacePad(val1);
zeroPad(val2);
spacePad(val2);
zeroPad(val3);
spacePad(val3);
void loop() {}
void zeroPad(float num) {
if (num < 1000) Serial.print("0");
if (num < 100) Serial.print("0");
if (num < 10) Serial.print("0");
Serial.print(num);
void spacePad(float num) {
if (num < 1000) Serial.print(" ");
if (num < 100) Serial.print(" ");
if (num < 10) Serial.print(" ");
Serial.println(num);
The results:
ZeroPad SpacePad
0255.00 255.00
0042.00 42.00
0000.15 0.15
