LCD display turns on, but doesn't display anything.
Hello everyone,
I am currently working on a university project where I have to build a Digital Alarm Clock. I started today and after 3 hours of programming I have stumbled upon the LCD display problem. I have connected the wires and written the code to display "Hello World" on the LCD screen. However, it is not displaying that. I am guessing it has something to do with the resistance in the potentiometer and the resistor which is connected to the display.
Here is the code :-
#include <LiquidCrystal.h>
int Celcius_Temp = 0;
int Fahrenheit_Temp = 0;
int RS_Pin = 12;
int Enable_Pin = 11;
int DB4_Pin = 5;
int DB5_Pin = 4;
int DB6_Pin = 3;
int DB7_Pin = 2;
LiquidCrystal lcd(RS_Pin, Enable_Pin, DB4_Pin, DB5_Pin, DB6_Pin, DB7_Pin);
  lcd.begin(16,2);
  lcd.print("Hello World!");
  pinMode(A0,INPUT); //Pin for the temperature sensor
  //Celcius_Temp = ((analogRead(A0) * (5.0/1024)) - 0.5)/0.01;
  //Fahrenheit_Temp = (Celcius_Temp * 9/5) + 32;
  //Serial.println(Celcius_Temp);
  delay(3000);
  lcd.clear();
I have attached the circuit as well. Let me know what I did wrong. I have been pulling my hair out on this problem for a long time. Your help will be much appreciated.
Thank You
Looks like you're missing a ground on R/W. Also, looks like you need to power VDD and ground VSS. I'm not personally experimenting with the effects of leaving those off, so I can't promise that's your problem. Here's the link to the recommended pinout: https://www.arduino.cc/en/Tutorial/LiquidCrystalDisplay
Also, once you get the hardware working, your code is set up to display something and then wait for 3 seconds and never display it again. You may have been aware of that already, but I just thought I should point that out in case you weren't.
You can try and turn the potentiometer on the display. That sets the contrast. It's a very usual issue.
Run the code and then turn the pot.
Expand<](LCD display turns on, but doesn't display anything. - Project Guidance - Arduino Forum)
A little hint to make it easier. Do not connect the potentiometer to 5 V. If it is a 10k potentiometer, connect both ends of the potentiometer to ground.
Obviously unless you connect pins 1, 2 and 5 correctly, it can never work. :grinning:
