lcd display -- using firmata and mega arduino
I fairly new to arduino and I have a few questions about a project I’m working on. I am trying to display images on an lcd display. Here is the hardware:
-3.2 TFT LCD display module
-Arduino mega & arduino mega shield
-Processing (firmata)
I have a processing sketch I would like to upload to the arduino and then display images on to the lcd display.
(I want to use the mouse to click through images on the lcd display)
This might be simple… But I’m having trouble integrating this arduino demo code:
#define LCD_RS 19
#define LCD_REST 16
#define LCD_WR 18
#define LCD_CS 17
void main_Write_COM(int DH)
  unsigned char i;
  int temp;
  digitalWrite(LCD_RS,LOW);
  digitalWrite(LCD_CS,LOW);
  for(i=0;i<16;i++)
    temp=(DH&0x01);
    if(temp)
      digitalWrite(i,HIGH);
      digitalWrite(i,LOW);
    DH=DH>>1;
  digitalWrite(LCD_WR,LOW);
  digitalWrite(LCD_WR,HIGH);
  digitalWrite(LCD_CS,HIGH);
void main_Write_DATA(int DH)
  unsigned char i;
  int temp;
  digitalWrite(LCD_RS,HIGH);
  for(i=0;i<16;i++)
    temp=(DH&0x01);
    if(temp)
    DH=DH>>1;
void main_W_com_data(int com1,int dat1)
  main_Write_COM(com1);
  main_Write_DATA(dat1);
void address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
  main_W_com_data(0x0002,x1>>8);     // Column address start2
  main_W_com_data(0x0003,x1);    // Column address start1
  main_W_com_data(0x0004,x2>>8);     // Column address end2
  main_W_com_data(0x0005,x2);    // Column address end1
  main_W_com_data(0x0006,y1>>8);     // Row address start2
  main_W_com_data(0x0007,y1);    // Row address start1
  main_W_com_data(0x0008,y2>>8);     // Row address end2
  main_W_com_data(0x0009,y2);    // Row address end1
  main_Write_COM(0x0022);
void main_init(void)
  digitalWrite(LCD_REST,HIGH);
  delay(5);
  digitalWrite(LCD_REST,LOW);
  delay(10);
  delay(20);
  //  VENDOR
  main_W_com_data(0x0046,0x00A4);
  main_W_com_data(0x0047,0x0053);
  main_W_com_data(0x0048,0x0000);
  main_W_com_data(0x0049,0x0044);
  main_W_com_data(0x004a,0x0004);
  main_W_com_data(0x004b,0x0067);
  main_W_com_data(0x004c,0x0033);
  main_W_com_data(0x004d,0x0077);
  main_W_com_data(0x004e,0x0012);
  main_W_com_data(0x004f,0x004C);
  main_W_com_data(0x0050,0x0046);
  main_W_com_data(0x0051,0x0044);
  //240x320 window setting
  main_W_com_data(0x0002,0x0000); // Column address start2
  main_W_com_data(0x0003,0x0000); // Column address start1
  main_W_com_data(0x0004,0x0000); // Column address end2
  main_W_com_data(0x0005,0x00ef); // Column address end1
  main_W_com_data(0x0006,0x0000); // Row address start2
  main_W_com_data(0x0007,0x0000); // Row address start1
  main_W_com_data(0x0008,0x0001); // Row address end2
  main_W_com_data(0x0009,0x003f); // Row address end1
  // Display Setting
  main_W_com_data(0x0001,0x0006); // IDMON=0, INVON=1, NORON=1, PTLON=0
  main_W_com_data(0x0016,0x00C8); // MY=0, MX=0, MV=0, ML=1, BGR=0, TEON=0   0048
  main_W_com_data(0x0023,0x0095); // N_DC=1001 0101
  main_W_com_data(0x0024,0x0095); // PI_DC=1001 0101
  main_W_com_data(0x0025,0x00FF); // I_DC=1111 1111
  main_W_com_data(0x0027,0x0002); // N_BP=0000 0010
  main_W_com_data(0x0028,0x0002); // N_FP=0000 0010
  main_W_com_data(0x0029,0x0002); // PI_BP=0000 0010
  main_W_com_data(0x002a,0x0002); // PI_FP=0000 0010
  main_W_com_data(0x002C,0x0002); // I_BP=0000 0010
  main_W_com_data(0x002d,0x0002); // I_FP=0000 0010
  main_W_com_data(0x003a,0x0001); // N_RTN=0000, N_NW=001    0001
  main_W_com_data(0x003b,0x0000); // P_RTN=0000, P_NW=001
  main_W_com_data(0x003c,0x00f0); // I_RTN=1111, I_NW=000
  main_W_com_data(0x003d,0x0000); // DIV=00
  delay(1);
  main_W_com_data(0x0035,0x0038); // EQS=38h
  main_W_com_data(0x0036,0x0078); // EQP=78h
  main_W_com_data(0x003E,0x0038); // SON=38h
  main_W_com_data(0x0040,0x000F); // GDON=0Fh
  main_W_com_data(0x0041,0x00F0); // GDOFF
  // Power Supply Setting
  main_W_com_data(0x0019,0x0049); // CADJ=0100, CUADJ=100, OSD_EN=1 ,60Hz
  main_W_com_data(0x0093,0x000F); // RADJ=1111, 100%
  delay(1);
  main_W_com_data(0x0020,0x0040); // BT=0100
  main_W_com_data(0x001D,0x0007); // VC1=111   0007
  main_W_com_data(0x001E,0x0000); // VC3=000
  main_W_com_data(0x001F,0x0004); // VRH=0011
  //VCOM SETTING
  main_W_com_data(0x0044,0x004D); // VCM=101 0000  4D
  main_W_com_data(0x0045,0x000E); // VDV=1 0001   0011
  delay(1);
  main_W_com_data(0x001C,0x0004); // AP=100
  delay(2);
  main_W_com_data(0x001B,0x0018); // GASENB=0, PON=0, DK=1, XDK=0, VLCD_TRI=0, STB=0
  delay(1);
  main_W_com_data(0x001B,0x0010); // GASENB=0, PON=1, DK=0, XDK=0, VLCD_TRI=0, STB=0
  delay(1);
  main_W_com_data(0x0043,0x0080); //set VCOMG=1
  delay(2);
  // Display ON Setting
  main_W_com_data(0x0090,0x007F); // SAP=0111 1111
  main_W_com_data(0x0026,0x0004); //GON=0, DTE=0, D=01
  delay(1);
  main_W_com_data(0x0026,0x0024); //GON=1, DTE=0, D=01
  main_W_com_data(0x0026,0x002C); //GON=1, DTE=0, D=11
  delay(1);
  main_W_com_data(0x0026,0x003C); //GON=1, DTE=1, D=11
  // INTERNAL REGISTER SETTING
  main_W_com_data(0x0057,0x0002); // TEST_Mode=1: into TEST mode
  main_W_com_data(0x0095,0x0001); // SET DISPLAY CLOCK AND PUMPING CLOCK TO SYNCHRONIZE
  main_W_com_data(0x0057,0x0000); // TEST_Mode=0: exit TEST mode
  //main_W_com_data(0x0021,0x0000);
void Pant(unsigned int color)
  int i,j;
  address_set(0,0,239,319);
  for(i=0;i<320;i++)
    for (j=0;j<240;j++)
      main_Write_DATA(color);
  unsigned char p;
  for(p=0;p<20;p++)
    pinMode(p,OUTPUT);
  main_init();
  Pant(0xf800); //Red
  Pant(0X07E0); //Green
  Pant(0x001f); //Blue
with my processing sketch:
import processing.serial.*;
import cc.arduino.*;
Arduino arduino;
PImage img0;
PImage img1;
PImage img2;
PImage img3;
int counter;
int ledPin = 13;
size(200,200);
arduino = new Arduino(this, Arduino.list()[0], 57600);
img0=loadImage(“0.png”);
img1=loadImage(“1.png”);
img2=loadImage(“2.png”);
img3=loadImage(“3.png”);
void draw() {
background(255,255);
if(counter == 1) {
image(img0, 0, 0);
if(counter == 2) {
image(img1, 0, 0);
if(counter == 3) {
image(img2, 0, 0);
if(counter == 4) {
image(img3, 0, 0);
void mousePressed(){
counter ++;
I am looking for any advice. Or the best way to go about this.
If you can help, please let me know. Thank you
I think you have some unrealistic expectations.
This will never happen. Processing compiles and links applications that run on a PC with a lot more memory, and integrated hardware, than an Arduino has.
The "image" needs to be defined in a way that the Arduino can understand it. Typically, this means as data in an include file. The Arduino then just sends this data to the appropriate pixel on the LCD. The data is a part of the sketch that is uploaded to the Arduino.
Sending a picture from a PC to the Arduino, for the Arduino to display on the PC [u]could[/u] be done. But, it won't be fast, and the size of the picture to display is still limited by the size of the LCD and the amount of memory that the Arduino has.
I'm working on a mac not a pc.
I understand everything that you are saying, and I know the function of the arduino. I should have reworded my first my phrase below about the processing sketch. I understand the communication that will be going on, I'm just stuck on the code.
Basically, I'm unclear about what I need to include in the code for each pixel on the lcd screen. If you or anyone else has advice, please let me know
thanks!
But I'm having trouble integrating this arduino demo code:
Where did you get this code? I'm not sure I've ever seen code that contained so few useful comments while at the same time stating the obvious on every line.
http://iteadstudio.com/application-note/demo-code-for-itdb02-tft-lcd/
this one is more accurate :
http://iteadstudio.com/application-note/itdb02-2-4-display-with-arduino/
