since yesterday I have my first arduino uno and connected a LCD / Keypad Shield "D1 Robot" to it. When I now tried several of the examples I found on the internet. Even if all were compiled and uploaded successfully, none of them showed anything on the display.
groundFungus:
Is there a potentiometer for adjusting the display contrast? Does adjusting it have any effect?
Well, yes there is, it is at the top left hand corner of the shield and it is a ten turn pot so to get the top row of "blocks" to show you have to turn it a number of times in one direction.
When I get the one I have just ordered, or find the one in my old collection, I could tell you which direction it needs to be turned,
thanks to both of you. I just wanted to reply, that there's a potentiometer. I already tried to turn it by my fingers. In the one direction I had the feeling it was at the "end position" (I couldn't turn further). In the other direction I could turn it a little bit, but it's not so easy doing it by fingers because it's too small (at least for my fingers). So I'll try when I'm at home with a screw driver.
Stupid question: Is there a possibility to "destroy" anything or to remove the screw from the potentiometer in case I drive too long?
Apparently the manufacturers realise just how absolutely certain would be the damage if there was a "hard" end-stop. The clicking is the permitted jumping of the screw spiral over the gear teeth on the rim of the actual potentiometer wheel.
thanks for your responses. Driving the potentiometer made it. The only problem I still had was, that I used lcd.noDisplay(), because yesterday I thought I can at least switch off the display. This shouldn't have been affected who lighted the display is,... But with my first tries adjusting the potentiometer, now, nothing changed, until I removed lcd.noDisplay(). Argh!
Now, it works quite fine.
@Emeritus: I meant I was sure, that the LCD has 2 rows and 20 cols, but since I didn't see them, I couldn't count. Now, I'll do and probably you are right, it's 2x16.
Thanks a lot! Now I'm even more motivated to extend the arduini + display with my ethernet shield, make the buttons work,...
