LCD equivalent of SSD1306 or SH1106 OLED displays
Is there an LCD display thats the same size and pixel count as the SSD1306 or SH1106 OLED displays ?
The SSD1306 or SH1106 are fine for small portable applications and with the U8X8 you get 8 lines of 16 characters which is OK.
But these displays are not very readable in direct sunlight, so are there any reflective type LCDs that are around the same size ?
Search for 128x64 COG (chip on glass) e.g. 40x35mm 128x64
Avoid anything that is white text on blue background.
The black text on white or yellow background should be fairly readable without backlight.
Use the backlight LED at night.
Note that most COG displays are 3.3V.
Surenoo seem to have a 38x37 display but without pcb .
This shop says that you can specify 5V or 3.3V for similar display
David.
