Hi All;
I have a sketch which reads in RFIDs and displays some words accordingly. The issue I have is that I have to set serial.begin(9600) for the RFID readers to work (ID-12) which causes the LCD to display garbled data. If I remove the line, then the LCD works just fine but the readers don't.
I even tested this with the Hello World code and got the same result.
#include <LiquidCrystal.h>
#define kLCD_RS 1 //PIN 4 on LCD
#define kLCD_EN 2 //PIN 6 on LCD
#define kLCD_DB4 3 //PIN 11 on LCD
#define kLCD_DB5 4 //PIN 12 on LCD
#define kLCD_DB6 A5 //PIN 13 on LCD
#define kLCD_DB7 A4 //PIN 14 on LCD
// initialize the library with the numbers of the interface pins
//LiquidCrystal lcd(kLCD_RS, kLCD_EN, kLCD_DB4, kLCD_DB5, kLCD_DB6, kLCD_DB7);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
As soon as I remove the serial.being(9600); it works. I am most likely dealing with a baud rate mismatch but I tried all the legal baud rates instead of 9600 and none allowed the LCD to work.
Can anyone offer any insight? Please....!
