I've built a process monitor which uses the psutil library to send data to my arduino formatted comma delimited. I am however encountering a flickering issue with the display in which it displaying the wrong data. I believe it is either shifting the information one character to either side, or picking up erroneous information via the serial.
Data is sent every 0.1 seconds so the update rate is quite quick, but I am confident the arduino can handle this. I have tested the display using a for loop to increment and print as fast as possible to the display and have no flickering issues such as I am experiencing.
As you can see the flicker at the location of the decimal places. It is hard to capture on photo but the flicker is very annoying in person as the whole thing flickers similarly especially the second line.
Data example: 33996,900660
I'm not sure how to troubleshoot this issue aside from trying different approaches and seeing if it fixes it. Due to it only happening at high rates of serial transfer It's hard to troubleshoot what the arduino "sees" because I can not receive the data back via serial in my setup.
My thoughts would be to implement a start and end delimiter, or sprintf formatting to format the floats specifically, however sprintf doesn't support float formatting on the arduino. When I had the text referenced to the numbers with spaces the entire messages moved as well so it has something to do with location referencing or losing a digit somewhere.
Any ideas or suggestions would be appreciated.
* SerialReceiveMultipleFields sketch
* This code expects a message in the format: 12,345,678
* This code requires a newline character to indicate the end of the data
* Set the serial monitor to send newline characters
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
byte downArrow[8] = {
0b01110,
0b01110,
0b01110,
0b01110,
0b01110,
0b11111,
0b01110,
0b00100
byte upArrow[8] = {
0b00100,
0b01110,
0b11111,
0b01110,
0b01110,
0b01110,
0b01110,
0b01110
const int NUMBER_OF_FIELDS = 2; // how many comma separated fields we expect
int fieldIndex = 0; // the current field being received
unsigned long values[NUMBER_OF_FIELDS]; // array holding values for all the fields
float upload = 0;
float download = 0;
Serial.begin(115200); // Initialize serial port to send and receive at 9600 baud
lcd.begin(16,2);
lcd.createChar(0, downArrow);
lcd.createChar(1, upArrow);
if( Serial.available())
char ch = Serial.read();
if(ch >= '0' && ch <= '9') // is this an ascii digit between 0 and 9?
// yes, accumulate the value if the fieldIndex is within range
// additional fields are not stored
if(fieldIndex < NUMBER_OF_FIELDS) {
values[fieldIndex] = (values[fieldIndex] * 10) + (ch - '0');
else if (ch == ',') // comma is our separator, so move on to the next field
fieldIndex++; // increment field index
// any character not a digit or comma ends the acquisition of fields
// in this example it's the newline character sent by the Serial Monitor
// print each of the stored fields
for(int i=0; i < min(NUMBER_OF_FIELDS, fieldIndex+1); i++)
values[i] = 0; // set the values to zero, ready for the next message
fieldIndex = 0; // ready to start over
writeData(values[0], values[1]);
void writeData(long firstLine, long secondLine){
if (firstLine > 0){
upload = values[0]/1024.0;
download = values[1]/1024.0;
lcd.setCursor(0,0);
lcd.print(upload);
lcd.setCursor(9,0);
lcd.print("MB");
lcd.setCursor(11,0);
lcd.write(byte(1)); //Print our up arrow
if (secondLine > 0){
lcd.setCursor(0,1);
lcd.print(download);
lcd.setCursor(9,1);
lcd.print("MB");
lcd.setCursor(11,1);
lcd.write(byte(0));
