LCD flickers for part of code but not all
So I am working on a project so that when nothing is pressed, the 16x2 lcd screen will display “press the button” and when you press it it will display “hello world” for 5 seconds and then return to the “press the button”. When I start up the arduino, it displays “press the button” but it doesn’t fully load and will look like it is trying to display it but just flickers. When I press the button, the hello world statement appears perfectly correct but then it will go back to the flickering of “press the button” after 5 seconds. I am pretty sure my wire setup is correct because it displays hello world fine.
Any ideas of why the “press the button” flickers so bad?
#include <LiquidCrystal.h>
const int but1 = 3;
const int but2 = 4;
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int buttonState = 0;
int buttonState1 = 0;
  lcd.begin(16, 2);
  pinMode(but1, INPUT);
  pinMode(but2, INPUT);
  lcd.clear();
  buttonState = digitalRead(but1);
    if (buttonState == LOW)
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("Press the button");
      lcd.display();
      if (buttonState == HIGH)
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("Hello");
    lcd.setCursor(0, 1);
    lcd.print("world");
    lcd.display();
    delay(5000);
    lcd.clear();
It's constantly clearing and showing 'Press the button' as fast as it can when your button is low, as written.
What I would do is just add the "Press a button" part once in setup(), and then once again after your 5 sec delay. Delete the 'if button is low' part.
So pressing a button will show "Hello World" for 5 seconds, then print "Press a button" just once until a button is pressed again.
You may also want to show us how your button is wired, because I have a feeling your button may be improperly resistored. And while fine for the current prog, you can look forward to button debouncing as you advance to new projects.
Look for a CHANGE in the button, not the current state of the button. Then most of the time the loop does nothing but check if the state changed.
