LCD functions won't work as intended
Hi guys,
I have a little problem. If i lcd.print("") in setup() it works fine, but if i call the same function in any other place, it doesn't show the intended string, just random characters.
This is the code:
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
const int rs = 7, en = 8, d4 = 9, d5 = 1, d6 = 2, d7 = 12;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
SoftwareSerial sim(10,11);
int _timeout;
String _buffer;
String number = "+40724330572"; //-> change with your number
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("s->trimite mesaj");
lcd.setCursor(0, 1);
lcd.print("c->suna");
delay(7000); //delay for 7 seconds to make sure the modules get the signal
_buffer.reserve(50);
Serial.println("Sistem Started...");
sim.begin(9600);
Serial.println("Type s to send an SMS, r to receive an SMS, and c to make a call");
if (Serial.available() > 0)
switch (Serial.read())
case 's':
SendMessage();
case 'r':
RecieveMessage();
case 'c':
callNumber();
if (sim.available() > 0)
Serial.write(sim.read());
void SendMessage()
//Serial.println ("Sending Message");
sim.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
//Serial.println ("Set SMS Number");
sim.println("AT+CMGS="" + number + ""\r"); //Mobile phone number to send message
String SMS = "Hello, how are you?";
sim.println(SMS);
delay(100);
sim.println((char)26);// ASCII code of CTRL+Z
_buffer = _readSerial();
void RecieveMessage()
Serial.println ("SIM800L Read an SMS");
delay (1000);
sim.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
Serial.write ("Unread Message done");
String _readSerial() {
_timeout = 0;
while (!sim.available() && _timeout < 12000 )
delay(13);
_timeout++;
if (sim.available()) {
return sim.readString();
void callNumber() {
sim.print (F("ATD"));
sim.print (number);
sim.print (F(";\r\n"));
Serial.println(_buffer);
Your code only prints to the LCD in setup()
Post a simple example of code that prints to LCD in loop() which does not work
I tried this without printing something in setup().
  lcd.print("SIM800L Read an SMS");    // Here !!!!!
  delay (1000);
Well done.
Well done what? :)))...it still doesn t work :frowning:
The sketch code in response #2 won't even build. A normal Arduino sketch needs a setup() and a loop() function.
--- bill
