LCD goes blank but code keeps running.
Hi All,
I have made a setup to control my terrarium which has a humidifier and heater connected to replays & LCD to display the humidity and temperature. I also have programmed in the average humidity & temperature to be displayed.
After its been running overnight theLCD screen goes blank but everything else seems to be running fine - the code continues to run.
Can any one shed some light on why this might happen?
#include <LiquidCrystal.h>
#include "DHT.h"
#define DHTPIN 6    // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
#define heaterpin 8
#define fanpin 9
#define humpin 10
#define arrsize 40
DHT dht(DHTPIN, DHTTYPE);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  float h;
  float t;
  int avgTemp;
  int avgHum;
  int timespass = 360;
  int tempArr[arrsize];
  int humArr[arrsize];
  int arrFill;
  int hum;
  int temp;
  dht.begin(); /// start temp sensor etc
  pinMode(heaterpin, OUTPUT);
  pinMode(fanpin, OUTPUT);
  pinMode(humpin, OUTPUT);
  lcd.begin(16, 2);
  h = dht.readHumidity();
  t = dht.readTemperature();
  hum = h;
  temp = t;
  checkHumidity(hum);
  checkTemp(temp);
  writeToArray();
  doAverages();
  writeToLCD();
  delay(5000);
void writeToArray(){
  timespass = timespass + 1;
  if(timespass > 360){   //720
    arrFill = arrFill + 1;
     if(arrFill = (arrsize)){
       arrFill = 1;
     humArr[arrFill] = hum;
     tempArr[arrFill] = temp;
     timespass = 0;
void doAverages(){
  avgTemp = 0;
  avgHum = 0;
  for(int x = 0; x <= arrFill; x = x + 1){
    avgTemp = avgTemp + tempArr[x];
    avgHum = avgHum + humArr[x];
  avgTemp = avgTemp / arrFill;
  avgHum = avgHum / arrFill;
void writeToLCD(){
    lcd.setCursor(0, 1);
    if(digitalRead(heaterpin) == LOW){
      lcd.print("T:On");
    }else{
      lcd.print("T:Off");
    if(digitalRead(humpin) == LOW){
      lcd.print(" H:On");
    }else{
      lcd.print(" H:Off");
    if(digitalRead(fanpin) ==LOW){
      lcd.print(" F:Off");
    }else{
      lcd.print(" F:On");
  lcd.setCursor(0, 0);
  lcd.print(temp);
  lcd.print("c");
  lcd.print(" ");
  lcd.print(hum);
  lcd.print("%  ");
  lcd.print(avgTemp);
  lcd.print("c");
  lcd.print(" ");
  lcd.print(avgHum);
  lcd.print("%");
void checkHumidity(int hum1){
  if(hum1 < 92){
    digitalWrite(humpin,LOW);
    digitalWrite(fanpin,LOW);
  }else if(hum1 > 86){
    digitalWrite(humpin,HIGH);
    digitalWrite(fanpin,HIGH);
void checkTemp(int temp1){
  if(temp1 < 24){
    digitalWrite(heaterpin,LOW);
  }else if(temp1 > 27){
    digitalWrite(heaterpin,HIGH);
I don’t have the hardware to really test this, but this statement:
is an assignment statement, not a logical test, so arrFill is set to 40. However, the next statement sets it equal to 1. This is because your assignment statement evaluates to logic True. I would put some print statements in, like:
void doAverages(){
  avgTemp = 0;
  avgHum = 0;
Serial.print)"i  = ");
Serial.print(i);
Serial.print)"   avgTemp = ");
Serial.println(avgTemp );
Serial.print)"   avgHum = ");
Serial.println(avgHum);
to make sure you are marching through all elements of the array.
How did i miss that! I will try it, thanks.
Any problems I have had with LCD screen are usually down to my wiring.
Its not the wiring because it works fine for a while and then goes kaput after a while
Lewisgmorris: it works fine for a while and then goes kaput after a while
From that you can not conclude
Intermittent connections, or poor soldered joints could still cause you problems.
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Tom..... :)
