LCD Help Coding
maybe..
  https://forum.arduino.cc/t/lcd-help-coding/1277759
#include <LiquidCrystal.h>
// Initialize the LCD library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int photoresistorPin = A0;
const int buttonPin = 7;
bool lightDetected = false; // Flag to track if light is detected
byte buttonPressed = 1; // Flag to track if last button state
String currentText = "text1";
String buttonText = "text2";
//starts with the current text
String displayText = currentText;
//flag to know which text..
byte textFlag = 0;
byte stateSys = 0;
unsigned long lastMove = 0;
unsigned long intervalMove = 2000;
unsigned long lastPress = 0;
unsigned long debounceDelay = 50;
  // Set up the LCD's number of columns and rows
  lcd.begin(16, 2);
  pinMode(buttonPin, INPUT_PULLUP);
  // Don't print anything initially
  unsigned long now = millis();
  int sensorValue = analogRead(photoresistorPin);
  if ( now - lastPress >= debounceDelay) {
    byte buttonState = digitalRead(buttonPin);
    if (buttonState != buttonPressed) {
      //button change, start debouncing
      lastPress = now;
      buttonPressed = buttonState; // remember
      if (buttonState == LOW) {
        if (textFlag < 1) {
          displayText = buttonText;
          textFlag = 1;
          textFlag = 0;
        if (stateSys > 1) stateSys = 1;
  // Adjust this threshold based on your environment
  if (sensorValue > 500) {
    lightDetected = true;
    //only if less than 1, could be scrolling state 2
    if (stateSys < 1) {
      stateSys = 1;
    stateSys = 0;
  switch (stateSys) {
    case 0: lcd.clear(); //no light just Clear the LCD
    case 1: lcd.clear(); // Clear the LCD
      // Print the message at the beginning of the first row
      lcd.setCursor(0, 0);
      lcd.print(displayText);
      //setup 2 second delay
      lastMove = now;
      intervalMove = 2000;//delay for static text
      stateSys = 2;
      break; //light first detect
    case 2: if (now - lastMove >= intervalMove) {
        lastMove = now;
        intervalMove = 1000;// scrolling delay..
        lcd.scrollDisplayLeft(); // Scroll the display to the left
~q
that works perfectly! Thank you so much.
you're welcome..
have fun.. ~q
