I am working with the ezmp3 shield to play mp3 files. I am using one of the examples as a base. When I cycle through the tracks (I have 15 at the moment), after I get to track 15, and push the button to go back to track 1, the second digit does not remove, on the display it shows the new track as 15(instead of 1)( then track 2 looks like 25, only the first digit changes. I can't find where or how to clear the second digit.
Durgensplayer.ino (4.7 KB)
#include <CytronEZMP3.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
CytronEZMP3 mp3;
byte vol = 15;
int i = 0;
int track = 0;
bool get_track_no = true;
//right, up, down, left, select
#define RightKey 0
#define UpKey 1
#define DownKey 2
#define LeftKey 3
#define SelectKey 4
#define NUM_KEYS 5
#define LED_PIN 13
unsigned int adc_key_val[5] ={50, 250, 400, 500, 800 };
byte key=-1;
byte oldkey=-1;
long timeout = 0;
long timeForDisp = 0;
boolean disp_flag = true;
boolean gotError = false;
// Convert ADC value to key number
byte get_key(unsigned int input)
for (byte k = 0; k < NUM_KEYS; k++)
if (input < adc_key_val[k])
return k;
return -1;
void Disp_vol(byte val)
lcd.clear();lcd.home();
lcd.print("Vol: ");
lcd.print(val);
lcd.begin(16,2);
lcd.clear();
pinMode(LED_PIN, OUTPUT);
lcd.print("My Personal");
lcd.setCursor(0, 1);
lcd.print("MP3 Player");
// set callback function before call begin()
mp3.setErrorCallback(errorCb);
if(!mp3.begin(2,3))
lcd.clear();
lcd.print("Init failed");
while(1);
mp3.setVolume(vol);
mp3.playTrack(1); // starting track
timeout = millis();
if(get_track_no)
track = mp3.getTrackNo();
get_track_no = false;
if(!mp3.isPlaying())
playNext();
if(disp_flag)
lcd.setCursor(0,0);lcd.print("Now Playing... ");
//scrollToLeft(i,1,"Track "+(String)track);
lcd.setCursor(0,1);lcd.print("Track "+(String)track);
key = get_key(analogRead(A0));
//Play Next Song when SelectKey pressed
if(key==SelectKey&&oldkey!=SelectKey)
playNext();// skip to next song
//Adjust Volume Up
else if(key==UpKey)
disp_flag = false;
timeForDisp = millis();
if(vol<30)
vol++;
mp3.setVolume(vol);
Disp_vol(vol);
delay(200);
//Adjust Volume Down
else if(key==DownKey)
disp_flag = false;
if(vol>0)
vol--;
mp3.setVolume(vol);
Disp_vol(vol);
delay(200);
//Mute the Player
else if(key==RightKey&&oldkey!=RightKey)
if(mp3.getVolume()==0)
lcd.print("Unmute");
mp3.setVolume(vol);
lcd.print("Mute");
mp3.setVolume(0);
disp_flag = false;
//delay(200);
//Pause the Player
else if(key==LeftKey&&oldkey!=LeftKey)
uint8_t _stat= mp3.getCurrentStatus();
if(_stat==0x02)
mp3.play();
lcd.print("Resume");
mp3.pause();
lcd.print("Pause");
disp_flag = false;
//delay(200);
oldkey = key;
if(millis()-timeout>1000)
i++;timeout = millis();
digitalWrite(LED_PIN, i%2);
if(millis()-timeForDisp>2000)
disp_flag = true;
void scrollToLeft(int index,int line,String dat)
lcd.setCursor(0,line);
dat = dat + " ";
index = index%dat.length();
if(index+16>dat.length())
lcd.print(dat.substring(index,dat.length())
+dat.substring(0,index+16-dat.length()));
lcd.print(dat.substring(index,index+16));
void playNext()
//Serial.println("Playing next song...");
mp3.next();
void playPrev()
//Serial.println("Playing previous song...");
delay(2000); // 2 sec is needed to initialise next song and play it
mp3.prev();
void errorCb()
Serial.print(F("[ERROR] "));
switch (mp3.errorCode()) {
case BUSY:
Serial.println(F("Busy"));
case SLEEPING:
Serial.println(F("In sleep mode"));
case SERIAL_WRONG_STACK:
Serial.println(F("Serial wrong stack"));
case CHECKSUM_ERR:
Serial.println(F("Checksum error"));
case FILE_OUT_OF_INDEX:
Serial.println(F("File number is out of index"));
case FILE_NOT_FOUND:
Serial.println(F("File not found"));
case DATA_MISMATCH:
Serial.println(F("Data mismatch"));
default:
Serial.println(F("Unknown error"));
while (1)
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
