LCD HORLOGE COMPILATION ERROR AFTER IT WORKED
Hello
I made some code, then transferred it to the arduino uno. When I wanted to make some changes to the code I had a compilation error. Could somebody help ?
#include <LiquidCrystal.h>
//8 bit: RS, RW, EN, D0, D1, D2, D3, D4, D5, D6, D7
//RS–>PC0
//RW–>PC1
//EN–>PC2
LiquidCrystal lcd(12, 13, 2, 8, 9, 10, 11, 4, 5, 6, 7);
#include “Wire.h”
#define DS1307_I2C_ADDRESS 0x68
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
// Stops the DS1307, but it has the side effect of setting seconds to 0
// Probably only want to use this for testing
/void stopDs1307()
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.write(0);
Wire.write(0x80);
Wire.endTransmission();
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you’re passing in valid numbers
void setDateDs1307(byte second, // 0-59
byte minute, // 0-59
byte hour, // 1-23
byte dayOfWeek, // 1-7
byte dayOfMonth, // 1-28/29/30/31
byte month, // 1-12
byte year) // 0-99
Wire.write(0);
Wire.write(decToBcd(second)); // 0 to bit 7 starts the clock
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour)); // If you want 12 hour am/pm you need to set
// bit 6 (also need to change readDateDs1307)
Wire.write(decToBcd(dayOfWeek));
Wire.write(decToBcd(dayOfMonth));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
// Reset the register pointer
Wire.write(0);
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
// A few of these need masks because certain bits are control bits
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f); // Need to change this if 12 hour am/pm
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
Wire.begin();
// Change these values to what you want to set your clock to.
// You probably only want to set your clock once and then remove
// the setDateDs1307 call.
second = 0;
minute = 20;
hour = 18;
dayOfWeek = 6;
dayOfMonth = 26;
month = 10;
year = 13;
//setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
lcd.setCursor(0,0);
delay(100);
getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
lcd.setCursor(0,0);
lcd.print(hour);
lcd.print(":");
lcd.print(minute);
lcd.print(":");
lcd.print(second);
Serial.print(" “);
Serial.print(month, DEC);
Serial.print(”/");
Serial.print(dayOfMonth, DEC);
Serial.print("/");
Serial.print(year, DEC);
Serial.print(" Day_of_week:");
Serial.println(dayOfWeek, DEC);
delay(100);
Which was..?
Please use code tags when posting code.
Compiles fine for me.
thank you for trying.
It did compile fine also first, but then it will show the following error :
In file included from sketch_oct26a.ino:6:
C:\Users\User\Documents\Arduino\libraries\LiquidCrystal/LiquidCrystal.h:19: error: conflicting return type specified for 'virtual void LiquidCrystal::write(uint8_t)'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
I tried the code you posted for a number of boards without problem on IDE 1.0.5 on Windows 7.
Please provide full details - IDE version, OS, board selected.
LiquidCrystal is now a core library. Get rid of your old version.
thank you
works again
