LCD i2c as a serial monitor
I am trying to make a counter for the amount of times that my fish swims by the front of his tank and I can figure out the code problems that I have been having. The code has been compiling but it keeps on putting out random letters and symbols to the LCD instead of the numbers. (I am new to coding c++)
Here is the code:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
#define trigPin 13
#define echoPin 12
const int led = 13;
int tcrt;
int counter = 0;
int currentState = 0;
int previousState = 0;
void setup(){
   // set up the LCD's number of columns and rows:
 lcd.init();
 lcd.backlight();
 // initialize the serial communications:
 pinMode(led, OUTPUT);
 pinMode(trigPin, OUTPUT);
 pinMode(echoPin, INPUT);
void loop(){
  long duration, distance;
 digitalWrite(trigPin, LOW);
 delayMicroseconds(2);
 digitalWrite(trigPin, HIGH);
 delayMicroseconds(10);
 duration = pulseIn(echoPin, HIGH);
 distance = (duration/2) / 29.1;
 if (distance <= 10){
 currentState = 1;
 else {
 currentState = 0;
 delay(100);
 if(currentState != previousState){
if(currentState == 1){
counter = counter + 1;
Serial.println(counter);
 tcrt = analogRead(A0);
 Serial.println(tcrt);
 lcd.home();
lcd.print(tcrt);
delay(0); // for testing only, wait 1 s before updating LCD with next number
 analogWrite(led, tcrt/4);
Welcome to the forum, and congratulations on using code tags with your first post.
Can you indeed sense the presence of the fish on the other side of the glass? I would have thought that the primary reflection from the glass or attenuation through the glass would be a problem, but if its working who can argue with success.
Now to the code. You should always use auto format found in the Tools pull down menu, or Ctrl + T from the keyboard. It helps when trouble shooting matching brackets problems.
First, can you run the library example for the lcd and see its proper operation? I actually can not confirm and display issues when I run your code with my setup.
Second, having the led and the trigger both on pin 13 appears to work, but it is not a good idea to use pin 13 as a general io pin. Additionally, is pin 13 a pwm pin on your Arduino?
The biggest issue that I see with your code(but it may not be the cause of the lcd issues) is that you never set previousState = currentState, and you will get multiple counts if an object is not moving but close enough to the sensor. You can do it here
 if (currentState != previousState) {
    previousState = currentState;
    if (currentState == 1) {
Finally, what is connected to A0 and what does the value of the reading indicate ?
Ok so here is the updated code:
#include <Wire.h>
#define trigPin 13
#define echoPin 12
const int led = 13;
int tcrt;
int counter = 0;
void setup(){
 lcd.init();
 lcd.backlight();
void loop(){
 currentState = 1;
 else {
 currentState = 0;
 delay(100);
 lcd.home();
lcd.print(tcrt);
I now am getting zeros after the number so now it wont print onto the LCD
And also here is the i2c library example that I am going off of:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x27 for a 16 chars and 2 line display
  lcd.init();                      // initialize the lcd
  lcd.backlight();
  // when characters arrive over the serial port...
  if (Serial.available()) {
    // wait a bit for the entire message to arrive
    delay(100);
    // clear the screen
    lcd.clear();
    // read all the available characters
    while (Serial.available() > 0) {
      // display each character to the LCD
      lcd.write(Serial.read());
tcrt is initialized as zero, and never takes on any other value.
#define trigPin 13
#define echoPin 12
const int led = 13;
You are using pin 13 for 2 different purposes
