#include "Wire.h"
#include <SD.h>
#include <DHT.h>
#define DS1307_ADDRESS 0x68
#define DHTPIN3 A0
#define DHTPIN2 A2
#define DHTPIN1 A1
#define DHTTYPE1 DHT11 // DHT 11
#define DHTTYPE2 DHT22 // DHT 22 (AM2302)
DHT dht1(DHTPIN1, DHTTYPE1);
DHT dht2(DHTPIN2, DHTTYPE1);
DHT dht3(DHTPIN3, DHTTYPE2);
LiquidCrystal_I2C lcd(0x24,20,4); // set the LCD address to 0x24 for a 16 chars and 2 line display
File myFile;
int latchPin =9;
int dataPin = 10;
int clockPin = 8;
int x =0;
//ShiftReg. 76543210
byte b1 = 0b11111111 ;
byte b2 = 0b00000000 ;
void setup(){
Wire.begin();
//Serial.begin(9600);
//setDateTime(); //MUST CONFIGURE IN FUNCTION
lcd.init();
lcd.backlight();
pinMode(latchPin,OUTPUT);
pinMode(dataPin,OUTPUT);
pinMode(clockPin,OUTPUT);
lcd.setCursor(0,0);
lcd.print(F(" **TempMon v1.02**"));
lcd.setCursor(0,1);
lcd.print(F(" Starting System...."));
if (!SD.begin(4)) {
lcd.setCursor(0,1);
lcd.print(F(" SD Shield ERROR !!!"));
return;
lcd.setCursor(0,1);
lcd.print(F(" SD Shield ON ")); }
dht1.begin();
dht2.begin();
dht3.begin();
lcd.clear();
void loop(){
// lcd.init();
lcd.setCursor(0,0);
lcd.print(F(" **TempMon System**"));
lcd.setCursor(2,2);
String dtime ="";
dtime += printDate();
lcd.print(dtime);
int h1 = dht1.readHumidity();
int t1 = dht1.readTemperature();
int h2 = dht2.readHumidity();
int t2 = dht2.readTemperature();
int h3 = dht3.readHumidity();
int t3 = dht3.readTemperature();
int Tmedia, Hmedia;
if (t1 < 1 || !isnan(t1)){ Tmedia = (t2+t3)/2;}
else if (t2 < 1 || !isnan(t2)) {Tmedia = (t1+t3)/2;}
else if (t3 <1 || !isnan(t3)) {Tmedia = (t2+t1)/2;}
else {Tmedia = (t1+t2+t3)/3;}
if (h1 < 1 || !isnan(h1)){ Hmedia = (h2+h3)/2;}
else if (h2 < 1 || !isnan(h2)) { Hmedia = (h1+h3)/2;}
else if (h3 < 1 || !isnan(h3)) {Hmedia = (h2+h1)/2;}
else { Hmedia = (h1+h2+h3)/3;}
int tsec=printSec();
int tmin=printMin();
lcd.setCursor(0,0);
lcd.print(F(" *Tm: "));
lcd.print(Tmedia);
lcd.print(F("C "));
lcd.print(F("*Hm: "));
lcd.print(Hmedia);
lcd.print(F("% "));
lcd.setCursor(0,1);
lcd.print(F(" T1: "));
lcd.print(t1);
lcd.print(F("C "));
lcd.print(F("H1: "));
lcd.print(h1);
lcd.print(F("% "));
lcd.setCursor(0,2);
lcd.print(F(" T2: "));
lcd.print(t2);
lcd.print(F("C "));
lcd.print(F("H2: "));
lcd.print(h2);
lcd.print(F("% "));
lcd.setCursor(0,3);
lcd.print(F(" T3: "));
lcd.print(t3);
lcd.print(F("C "));
lcd.print(F("H3: "));
lcd.print(h3);
lcd.print(F("% "));
dtime += "-";
dtime += Tmedia;
dtime += "-";
dtime += t1;
dtime += "-";
dtime += t2;
dtime += "-";
dtime += t3;
dtime += "-";
dtime += Hmedia;
dtime += "-";
dtime += h1;
dtime += "-";
dtime += h2;
dtime += "-";
dtime += h3;
delay(3000);
lcd.clear();
if (Tmedia < 22)
{ bitClear(b1,5);
lcd.setCursor(0,0);
lcd.print(F("Temperatura....BASSA"));
dtime += "-Temp. BASSA";
bitSet(b1,5); }
if (Tmedia > 32)
{ bitClear(b1,0);
bitClear(b1,1);
bitClear(b1,2);
bitClear(b1,3);
lcd.setCursor(0,0);
lcd.print(F("Temperatura.....ALTA"));
dtime += "-Temp. ALTA";
bitSet(b1,0);
bitSet(b1,1);
bitSet(b1,2);
bitSet(b1,3);}
if (Hmedia < 75)
{ bitClear(b1,6);
bitClear(b1,4);
lcd.setCursor(0,1);
lcd.print(F("Umidita........BASSA"));
dtime += "-Umid. BASSA";
bitSet(b1,6);
bitSet(b1,4); }
if (Hmedia > 95)
{ bitClear(b1,2); //top fan
bitClear(b1,0); //front 2
bitClear(b1,1); //front
lcd.setCursor(0,1);
lcd.print(F("Umidita.........ALTA"));
dtime += "-Umid. ALTA";
bitSet(b1,2);
bitSet(b1,1);
bitSet(b1,1);}
if (tmin < 8)
{ bitClear(b1,3);
bitClear(b1,2);
lcd.setCursor(0,2);
lcd.print(F("Ricambio Aria.....ON"));
dtime += "-Ric. ARIA";}
digitalWrite(latchPin,LOW);
shiftOut(dataPin, clockPin, LSBFIRST, b1);
shiftOut(dataPin, clockPin, LSBFIRST, b2);
digitalWrite(latchPin, HIGH);
delay(2000);
if (tsec < 5) {
File dataFile = SD.open("log.txt", FILE_WRITE);
if (dataFile) {
dataFile.println(dtime);
dataFile.close();
lcd.println(F("ERROR open log.txt"));
lcd.clear();
//************ INIZIO codice DS1307 *****************
void setDateTime(){
byte second = 16; //0-59
byte minute = 22; //0-59
byte hour = 23; //0-23
byte weekDay = 4; //1-7
byte monthDay = 23; //1-31
byte month = 5; //1-12
byte year = 13; //0-99
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write(0); //stop Oscillator
Wire.write(decToBcd(second));
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(decToBcd(weekDay));
Wire.write(decToBcd(monthDay));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.write(0); //start
Wire.endTransmission();
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val) {
// Convert binary coded decimal to normal decimal numbers
return ( (val/16*10) + (val%16) );
String printDate(){
// Reset the register pointer
Wire.write(0);
Wire.requestFrom(DS1307_ADDRESS, 7);
int second = bcdToDec(Wire.read());
int minute = bcdToDec(Wire.read());
int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
int monthDay = bcdToDec(Wire.read());
int month = bcdToDec(Wire.read());
int year = bcdToDec(Wire.read());
String dataora = "";
//print format date ES. 3/1/11 23:59:59
dataora +=monthDay;
dataora +="/";
dataora +=month;
dataora +="/";
dataora +=year;
dataora +=" ";
dataora +=hour;
dataora +=":";
dataora +=minute;
dataora +=":";
dataora +=second;
return dataora;
int printSec(){
Wire.write(0);
return second;
int printMin(){
Wire.write(0);
return minute;
//************ FINE codice DS1307 *****************
https://docs.google.com/file/d/0ByoKd_e1bIw5UTJOTUpKRFR1ZEE/edit?usp=sharing
Spero sia sufficiente............considerando che sono un princiante
