I keep work very hard with this code, but with lcd.begin the motor doesn't word
#include <IRremote.h>
#include <Adafruit_LiquidCrystal.h>
Adafruit_LiquidCrystal lcd_1(0);
const int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
// motor_1 control pin
const int motorDirPin_motor1 = 5; // Input 1
const int motorPWMPin_motor1 = 6; // Input 2
const int EnablePin = 9; // Enable
const int LED = 13;
// encoder_1 pin
const int encoderPinA_motor1 = 2;
const int encoderPinB_motor1 = 4;
int16_t encoderPos_motor1 = 0;
// motor_2 control pin
const int motorDirPin_motor2 = 10; // Input 1
const int motorPWMPin_motor2 = 11; // Input 2
// encoder_2 pin
const int encoderPinA_motor2 = 3;
const int encoderPinB_motor2 = 8;
int16_t encoderPos_motor2 = 0;
const unsigned int TRIG_PIN_L=A0;
const unsigned int ECHO_PIN_L=A1;
const unsigned int TRIG_PIN_F=A2;
const unsigned int ECHO_PIN_F=1;
const unsigned int TRIG_PIN_R=13;
const unsigned int ECHO_PIN_R=12;
const unsigned int ledPin = 0;
const unsigned int pR = A3;
bool status = false;
// encoder value change motor turn angles
const float ratio = 360./2200;
// control_motor_1
float Kp_motor1 = 50;
float Kd_motor1 = 0;
float targetDeg_motor1 = 0; // input target Degree position.
// control_motor_2
float Kp_motor2 = 50;
float Kd_motor2 = 0;
float targetDeg_motor2 = 10; // input target Degree position.
int count = 0;
int pRA;
int countClick = 0;
int distF;
int distR;
int distL;
//pinMode(TRIG_PIN, OUTPUT);
//pinMode(ECHO_PIN, INPUT);
//pinMode(EnablePin, OUTPUT);
pinMode(ledPin,OUTPUT);
// Setup_motor1
pinMode(encoderPinA_motor1, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(encoderPinA_motor1), doEncoder_motor1, RISING);
pinMode(encoderPinB_motor1, INPUT_PULLUP);
pinMode(motorDirPin_motor1, OUTPUT);
// Setup_motor2
pinMode(encoderPinA_motor2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(encoderPinA_motor2), doEncoder_motor2, RISING);
pinMode(encoderPinB_motor2, INPUT_PULLUP);
pinMode(motorDirPin_motor2, OUTPUT);
irrecv.enableIRIn();
irrecv.blink13(true);
//attachInterrupt(digitalPinToInterrupt(int0Pin), blink, RISING);
// initialize timer1
//noInterrupts(); // disable all interrupts
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
int mSecs = 500; //ms
OCR1A = (16e6 / 256L * mSecs) / 1e3 - 1; // compare match register 16MHz/256/2Hz
TCCR1B |= (1 << WGM12); // CTC mode
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
//interrupts(); // enable all interrupts
ISR(TIMER1_COMPA_vect) // timer compare interrupt service routine
blink();
void blink() {
if (irrecv.decode(&results)){
if (results.value == 0xFD00FF ){
countClick++;
Serial.println(countClick);
else if(status && results.value == 0xFD40BF){
count++;
irrecv.resume();
if(countClick%2 ==0 ){
status = false;
digitalWrite(ledPin,LOW);
}else{
status = true;
distF = readUltrasonicDistance(TRIG_PIN_F,ECHO_PIN_F);
distL = readUltrasonicDistance(TRIG_PIN_L, ECHO_PIN_L);
distR = readUltrasonicDistance(TRIG_PIN_R, ECHO_PIN_R);
void doEncoder_motor1() {
if (digitalRead(encoderPinB_motor1)==0) {
encoderPos_motor1--;
} else if (digitalRead(encoderPinB_motor1)==1) {
encoderPos_motor1++;
void doEncoder_motor2() {
if (digitalRead(encoderPinB_motor2)==LOW) {
encoderPos_motor2--;
} else if (digitalRead(encoderPinB_motor2)==HIGH) {
encoderPos_motor2++;
void doMotor1(bool dir_1, int vel_1) {
digitalWrite(motorDirPin_motor1, dir_1);
if(dir_1 == 1) {
analogWrite(motorPWMPin_motor1, 255 - vel_1);
analogWrite(motorPWMPin_motor1, vel_1);
void doMotor2(bool dir_2, int vel_2) {
digitalWrite(motorDirPin_motor2, dir_2);
if(dir_2 == 1) {
analogWrite(motorPWMPin_motor2, 255 - vel_2);
analogWrite(motorPWMPin_motor2, vel_2);
void control_motor1() {
float motorDeg_motor1 = float(encoderPos_motor1)*ratio;
float error_1_motor1 = targetDeg_motor1 - motorDeg_motor1;
float control_motor1 = Kp_motor1*error_1_motor1;
digitalWrite(EnablePin, 255);
doMotor1((control_motor1>=0)?HIGH:LOW, min(abs(control_motor1), 255));
void control_motor2() {
float motorDeg_motor2 = float(encoderPos_motor2)*ratio;
float error_1_motor2 = targetDeg_motor2 - motorDeg_motor2;
float control_motor2 = Kp_motor1*error_1_motor2;
doMotor2((control_motor2>=0)?HIGH:LOW, min(abs(control_motor2), 255));
int readUltrasonicDistance(int triggerPin, int echoPin) {
pinMode(triggerPin, OUTPUT); // Clear the trigger
digitalWrite(triggerPin, LOW);
delayMicroseconds(2);
// Sets the trigger pin to HIGH state for 10 microseconds
digitalWrite(triggerPin, HIGH);
delayMicroseconds(10);
pinMode(echoPin, INPUT);
// Reads the echo pin, and returns the sound wave travel time in microseconds
return pulseIn(echoPin, HIGH)*0.0343/2;
lcd_1.begin(16, 2);
int value;
lcd_1.setCursor(10, 0);
switch(count){
case 1:
digitalWrite(ledPin,HIGH);
lcd_1.print("* ");
case 2:
lcd_1.print(" ");
case 3:
pRA = analogRead(pR);
value = map(pRA, 0, 1023, 0, 255);
if(value <30){
}else{
lcd_1.print("Auto");
default:
count = 0;
if(status){
control_motor1();
//delay(5);
control_motor2();
//delay(5);
lcd_1.setCursor(0, 1);
if (distF > 100) {
lcd_1.print("Going Straight! ");
lcd_1.setBacklight(1);
if ((distL > 100 && distR < 100) || (distL > 100 && distR > 100)) {
//turn left
targetDeg_motor1 = 50;
lcd_1.print("Turning left ");
//targetDeg_motor2 = 0;
} else if (distR > 100) {
//turn right
targetDeg_motor1 = -50;
lcd_1.print("Turning right ");
targetDeg_motor2 = -10;
targetDeg_motor1 = -80;
lcd_1.print("Reversing ");
}else{
lcd_1.print("Car is off! ");
count = 0;
