Resume;
And LCD 20x04, is stoping to be outputing text, and only sow symbols and random stuff. Its is used to control a 220V industrilal refrigeration room.
-Yes it has snubbers
-Yes it has 2 2.2K resistor to keep the SDA and SCL at high
The set up;
-Arduino Mega
-8 Relay Strip
-Lcd Display 20x04 and IC2 adapter
-Buck converter.
-Capacitor filter to smooth voltage of the buck converter.
aaa]aaa
The thing itself starts and works properly, the code dont frezee. But once I was watching, the lcd display become full os random simbols when the system stop... It meas the relays was open and since I dont have a scope I can only assume the High voltage peaks damage the data trasmiton.
After some research, a post of Nick Gammon strongly suggest the use of 2.2K resistor to keep the SDA and the SCL at high mode, I install one of these... buth the problem persist.
So I make some snubbers out of 400pF and 8W 300ohm resistors and put in parallel with the main contacts of the 3 mayor inductive loads...
2 evaporator fans (5 small fans) rating 2.5A
1 Relay coil (the contactor of the compressor unit)
And the screen was legible for much much longer, it dont clear at start or stop. The thing is ... it clears or it become full of garbage at some point during the day.
So, I will add another snubber for the other major inductive load, a solenoid coil, yet, I dont know whath is more recomendably for it a snubber or a variac?
Thanks for your tougths on this so far.
I was reading I migth be necessary a capacitor in the pin 1 and 2 of the LCD.... "First try - a 47 µF capacitor connected between pins 1 and 2 on the LCD." on another topic.
Main Questions is... The solenoid coil must be in parallel with a snubber or with a varistor ?
Thanks in advance.
-Alex.
