LCD Important
Hi, I'm new to this site, I'm 17, I'm Italian and I'm working on a project for school.
My problem is that the LCD does not make me get out of the DO-WHILE loop.
If I delete the DELAY, I am out of the loop but to update the sensor values, I must continually press the KEY 'A' because I planned a switch that can be controlled from a keyboard.
Here's the code:
char key = keypad.getKey();
if(key) // Check for a valid key.
switch (key)
case 'A':
do{
for (int u=0; u<=50; u++)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Temperatura 00");
lcd.setCursor(15,0);
lcd.print("C");
//GAS
lcd.setCursor(0,1);
lcd.print("Gas ");
lcd.setCursor(5,1);
SensoreGas = analogRead(A8);
lcd.print(SensoreGas);
delay(1000); // QUESTO E' IL DELAY CHE HO CITATO POCO FA
}while(key!='A');
You don't get a new key value in the do..while loop.
Please remember to use code tags when posting code.
