Hello, I am currently doing a school project where I need to code 2 LCD screens to read the current score of both players. The LCD should take indirect input from the PIR Motion sensors which make either integer 'x' or 'y' increment by one. In the end, once one score reaches 10, the LDC should clear and reset.
I can't fully understand where to put certain parts of code to make them run my desired way.
Heres said code:
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int pin_to_sensor = 9;
const int PIN_TO_SENSOR = 8; // the pin that OUTPUT pin of sensor is connected to
int pinStateCurrent = LOW;
int pinStatePrevious = LOW; // previous state of pin
int x = 0;
int y = 0;
pinMode(8, INPUT);
pinMode(9, INPUT);
lcd.begin(16,1);
int x = constrain(x, 0, 10);
int y = constrain(y, 0, 10);
void screen() {
lcd.print(F("Player 2:"));
lcd.print(F("Player 1:" ));
void score() {
if (8, HIGH) {
++y ;
lcd.print( 'y' );
delay(2000);
else (9, HIGH); {
++x;
lcd.print( 'x' );
delay(2000);
pinStatePrevious = pinStateCurrent;
pinStateCurrent = digitalRead(8);
pinStateCurrent = digitalRead(9);
void score();
void screen();
lcd.noAutoscroll();
ANY and ALL help is appreciated. P.S I only just started learning Arduino about a year ago so please go easy on me.
You forgot to tell us how you actually wired the LCD, and to explain the actual problem you are having. Also, please use code tags when posting code. Check the posting guides for instructions.
Start with some clear, very simple example and make sure you get it working, before trying to write your own code.
Don't forget that many LCD displays have a contrast potentiometer, and it must be set correctly to see the displayed characters.
I would just post an attachment but sadly the forum will not let me. If I must be more in-depth the 4 data pins of the LDC are left with nothing in them as they should be; the LCD is on both backlight, and screen; just nothing is printed to it. However, it was printing before just not what I intended so I do not believe the problem lies within the wiring. The potentiometer is also allowing enough voltage so you would easily be able to see what is printed on the screen.
Go back to what you had "before", make sure that it still prints, then make changes in the code one at a time. If the LCD stops printing, the last change was incorrect.
