LCD Keypad Shield
Salve a tutti. Ho acquistato la shield keypad ed ho provato a caricare il programma che era presente sul wiki di questo oggetto, ovvero:
//Sample using LiquidCrystal library
#include <LiquidCrystal.h>
This program will test the LCD panel and the buttons
Mark Bramwell, July 2010
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
int read_LCD_buttons()
 adc_key_in = analogRead(0);      // read the value from the sensor
 // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
 // we add approx 50 to those values and check to see if we are close
 if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
 // For V1.1 us this threshold
 if (adc_key_in < 50)   return btnRIGHT;
 if (adc_key_in < 250)  return btnUP;
 if (adc_key_in < 450)  return btnDOWN;
 if (adc_key_in < 650)  return btnLEFT;
 if (adc_key_in < 850)  return btnSELECT;
 // For V1.0 comment the other threshold and use the one below:
 if (adc_key_in < 195)  return btnUP;
 if (adc_key_in < 380)  return btnDOWN;
 if (adc_key_in < 555)  return btnLEFT;
 if (adc_key_in < 790)  return btnSELECT;
 return btnNONE;  // when all others fail, return this...
 lcd.begin(16, 2);              // start the library
 lcd.setCursor(0,0);
 lcd.print("Push the buttons"); // print a simple message
 lcd.setCursor(9,1);            // move cursor to second line "1" and 9 spaces over
 lcd.print(millis()/1000);      // display seconds elapsed since power-up
 lcd.setCursor(0,1);            // move to the begining of the second line
 lcd_key = read_LCD_buttons();  // read the buttons
 switch (lcd_key)               // depending on which button was pushed, we perform an action
   case btnRIGHT:
     lcd.print("RIGHT ");
   case btnLEFT:
     lcd.print("LEFT   ");
   case btnUP:
     lcd.print("UP    ");
   case btnDOWN:
     lcd.print("DOWN  ");
   case btnSELECT:
     lcd.print("SELECT");
     case btnNONE:
     lcd.print("NONE  ");
ma io sul display visualizzo dei caratteri e lettere che non c’entrano nulla.
Come posso risolvere?
Grazie
Quale schedina hai? (modello produttore o link dove l’ hai comprata).
Grazie per l’illuminazione :slight_smile: ho preso la scheda che va bene per arduino 2009 http://dx.com/p/lcd-keypad-shield-for-arduino-duemilanove-lcd-1602-118059 ma sto utilizzando arduino UNO. C’è un modo per adattarla?
Anche se sinceramente non capisco in cosa differiscono le due shield…
Nei commenti ho letto che è compatibile anche con arduino UNO quindi non è quello il problema
La scritta "hello, world!" la leggo così sul display "hdlln, fnbld"
Strano difetto... sostituisce la "e" con "d", la "o" con "n", la "w" con la "f" e la "r" con la "b".
Prova a stampare le stringhe ABCDEFGHIJKLMNO e abcdefghijlmno
Controlla se non c’é un corto tra 2 piedini del display e/o connettore Arduino.
Ciao Uwe
Ho provato e mi compare sul display: "@BBDDFFHHJJLLNN" e l'altro " 'bbddffhhjllnn"
Uwe corti non penso perchè non l'ho nemmeno saldato io comunque controllo lo stesso.
Ho provato a scrivere questo semplice programma
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 0);
  // print the number of seconds since reset:
  lcd.print("ABCDEFGHIJKLMNO");
  lcd.setCursor(0, 1);
  lcd.print("abcdefghijlmno");
  lcd.clear();
in realtà lo schermo dovrebbe cancellarsi tutto per un secondo giusto? perchè io vedo sempre le scritte (quelle che ho riportato sopra).
Il pin D4 è normale che sia unito a Vss? perchè se passo con il Tester sento che suona
No, non è normale. Il D0, D1, D2 e D3 non devono essere collegati, mentre il D4, D5, D6 e D7 dovrebbero essere collegati ad altrettanti pin di Arduino (4, 5, 6, 7).
LiquidCrystal(rs, enable, d4, d5, d6, d7)
Ma se è così come posso risolvere?
Forse il problema è un banale corto sulla linea D4: potrebbe essere uno sbavo di stagno.
Tuttavia se la scheda è in garanzia, ti converrebbe rivolgerti al venditore.
davix10: ... ho preso la scheda che va bene per arduino 2009 http://dx.com/p/lcd-keypad-shield-for-arduino-duemilanove-lcd-1602-118059 ...
Posso supporre che tu avessi gia visto i commenti di altri utenti che hanno acquistato quel display, a fondo pagina ? ... come, ad esempio, dove dicono: "Also works using the standard LiquidCrystal library. Please note: The data-pins are -not- arranged as they are for the Hitachi-driver! Therefor, the Arduino Example-sketches will NOT work by default with this display! To make the display work, use the following sequence of pins when starting the library: LiquidCrystal lcd(8, 9, 4, 5, 6, 7);" ;)
Inoltre in fondo, nelle discussioni, ci sono altri esempi e pezzi di codice (bisogna aprirle in altre pagine), magari c'e' qualcosa di utile anche li ...
Si ma il codice del mio programma è già questo
non capisco cosa possa essere
Qui c’è l’esempio di cosa appare sul display, ho provato con “hello” e “abcdefghijlmno”.
