Hi community!
Ok, I've been working on P10 panels lately, would love to use a keypad to set the display after going through all the settings I made (speed, language of display, ...)
Everything was running pretty fine before adding the DMD code, once I confirm and click on "#" the message will start scrolling then I can't update it or use both the LCD and the keypad
I tried to use the goto but I faced the same problem
Thanks for you help.
#include <Keypad.h>
#include <Wire.h>
#include <SPI.h>Â Â Â Â
#include <DMD.h>Â Â Â Â
#include <TimerOne.h>
#include "AR.h"
#define codeLenght 4 // Give enough room for 3 chars + NULL char
//DMD
#define DISPLAYS_ACROSS 3
#define DISPLAYS_DOWN 1
//LCD
LiquidCrystal_I2C lcd(0x27, 20, 4);//0x27 0x38
//KeyPad
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
 {'1','2','3','A'},
 {'4','5','6','B'},
 {'7','8','9','C'},
 {'*','0','#','D'}
byte rowPins[ROWS] = {2, 3, 4, 5};
byte colPins[COLS] = {A0, A1, A2, A3};
Keypad myKeypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
char Code[codeLenght];
char Speed;
byte codeCount = 0;
boolean mode = false;
boolean Display = false;
int page;
int value;
char Key;
String language;
String MSG;
unsigned long time;
int n;
boolean ret = false;
DMD dmd(DISPLAYS_ACROSS , DISPLAYS_DOWN);
void ScanDMD(){
 dmd.scanDisplayBySPI();
void setup(){
 lcd.init();
 lcd.backlight();
 myKeypad.addEventListener(keypadEvent);
 Timer1.initialize(3000);  Â
 Timer1.attachInterrupt(ScanDMD);Â
 dmd.selectFont(AR);
 dmd.clearScreen(true);
void loop(){
 char key = myKeypad.getKey();
 if(mode){
  if(key == '*'){
   mainMenu();
   page = 0;
  if(page == 0){
   if(key == '1'){
    lanMenu();
   if(key == '2'){//page 3
    page = 2;
    lcd.clear();
    lcd.setCursor(7, 0);
    lcd.print("SPEED");
    lcd.setCursor(2, 1);
    lcd.print("Enter Your Speed");
    lcd.setCursor(12, 3);
    lcd.print("(*) Back");
  if(page == 1){
   if(key == '1'){
    lcd.clear();
    lcd.setCursor(2, 0);
    lcd.print("Language Display");
    lcd.setCursor(7, 1);
    lcd.print("French");
    language = "FR";
   if(key == '2'){
    lcd.clear();
    lcd.print("English");
    language = "EN";
   if(key == '3'){
    lcd.clear();
    lcd.setCursor(8, 1);
    lcd.print("Mix");
    language = "MX";
   if(page == 2){
    if(key){
     Speed = key;
     lcd.setCursor(9, 2);
     lcd.print(Speed);
    Â
  if(key == '#'){
   mode = false;
   Display = true;
   Serial.print("lineId: ");Serial.println(value);
   Serial.print("lineName: ");Serial.println(MSG);
   Serial.print("Language: ");Serial.println(language);
   Serial.print("Speed: ");Serial.println(Speed);
   Serial.print("\n");
   lcd.clear();
 else{
  lcd.setCursor(0,0);
  lcd.print(" Enter Your Code");
Â
  if(key){
   Code[codeCount] = key; // store char into data array
   lcd.setCursor(8 + codeCount,2); // move cursor to show each new char
   lcd.print(Code[codeCount]); // print char at said cursor
   codeCount++; // increment data array by 1 to store new char, also keep track of the number of chars entered
  if(codeCount == codeLenght-1){ // if the array index is equal to the number of expected chars, compare data to master
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print(Code);
  lcd.setCursor(0, 1);
  value = atoi(Code);
  switch(value){
   case 100:
    mode = true;
    MSG = "Bus Special";
    lcd.print(MSG);
    lcd.setCursor(0, 3);
    lcd.print("(*) Menu  (#) Exit");
   case 102:
    mode = true;
    MSG = "Bla Bla Bla";
    lcd.print(MSG);
   case 201:
    mode = true;
    lcd.print(MSG);
   case 217:
    mode = true;
    lcd.print(MSG);
   case 229:
    mode = true;
    MSG = "Bla Bla Bla ";
    lcd.print(MSG);
   default:
    mode = false;
    Display = true;
    value = "\0";
    MSG = "";
    lcd.print("Invalid Code");
    delay(2000);
    lcd.clear();
  clearCode();
 dmd.drawString(0, -1, String(value).c_str(), 3, GRAPHICS_NORMAL);
 dmd.drawMarquee(MSG.c_str(), strlen(MSG.c_str()), (32*DISPLAYS_ACROSS)-1, -1); //strlen
 time = millis();
  n=0;
  while(n<1){
   while(!ret){
    if((time+30) < millis()){
     ret = dmd.stepSplitMarquee(0,16,30);
     time=millis();
   ret = false;
   n++;
Â
void keypadEvent(KeypadEvent key){
  switch (myKeypad.getState()){
  case PRESSED:
   Â
  case RELEASED:
    if (key == '1' && page == 0) {
      if(mode)page = 1;
  case HOLD:
    if (key == '*'){
    Â
void mainMenu(){
 lcd.clear();
 lcd.setCursor(8, 0);
 lcd.print("MENU");
 lcd.print("(1) Language");
 lcd.setCursor(0, 2);
 lcd.print("(2) Speed");
 lcd.print("(#) Exit");
void lanMenu(){
 lcd.clear();
 lcd.setCursor(6, 0);
 lcd.print("LANGUAGE");
 lcd.print("(1) FR (2) EN");
 lcd.print("(3) MIX");
void clearCode(){
 while(codeCount !=0 ){ // This can be used for any array size,
  Code[codeCount--] = 0; //clear array for new data
 return;
