Hi, I have been working on an Arduino controlled preamp system. I am just trying to create the menu structure so that the user is able to cycle through different options. However I am having a problem with sub-menus just doesn't work as I expected. Here is the code I have so far I have put a comment at the top of where the issue starts.
#include <LiquidCrystal.h>
#include <string.h>
/* DIO pin definitions */
#define LCD_DATA4 4 /* LCD data DIO pin 4 */
#define LCD_DATA5 5 /* LCD data DIO pin 5 */
#define LCD_DATA6 6 /* LCD data DIO pin 6 */
#define LCD_DATA7 7 /* LCD data DIO pin 7 */
#define LCD_RESET 8 /* LCD Reset DIO pin */
#define LCD_ENABLE 9 /* LCD Enable DIO pin */
#define LCD_BACKLIGHT 10 /*LCD backlight DIO pin */
LiquidCrystal lcd(LCD_RESET, LCD_ENABLE, LCD_DATA4, LCD_DATA5, LCD_DATA6, LCD_DATA7);
// set lcd size
lcd.begin(16,2);
Serial.begin(9600); //trying to debug
MainMenu();
String screen(int level, int pos) //function to return correct string value
String string;
if (level == 0 && pos == 1)
string = " Input: ";
else if (level == 0 && pos == 2)
string = " Volume: ";
else if (level == 0 && pos == 3)
string = " Bass: ";
else if (level == 0 && pos == 4)
string = " Balance: ";
else if (level == 2 && pos == 1)
string = " 20 dB ";
else if (level == 1 && pos == 1)
string = " 7.1 in ";
else if (level == 1 && pos == 2)
string = " e5.1 in ";
else if (level == 1 && pos == 3)
string = " 2.1 in ";
else if (level == 1 && pos == 4)
string = " 2.0 in ";
return string;
void scrnprint(int level, int subLevel) //prints main screen
ClearLCD();
lcd.setCursor(0,0);
lcd.print(screen(level,subLevel));
void scrnprintsub(int level, int subLevel,int edit) //prints screen when sub menu is visible
byte ArrowsUD[8] = {
B00100,
B01110,
B11111,
B00000,
B11111,
B01110,
B00100,
lcd.createChar(0,ArrowsUD);
lcd.setCursor(0,0);
lcd.print(screen(0,level));
lcd.setCursor(0,1);
if (edit == 1)
lcd.write(byte(0));
lcd.print(" ");
void MainMenu()
byte pos = 1,subpos = 1, inputSelected = 1;
ClearLCD();
scrnprintsub(1,inputSelected,0); // prints initial value of Input: with 7.1
do
switch(LCDState()) // calls LCDState to get key press
case 8: //value correspond to numpad direction arrows
pos++;
if (pos > 4)
pos = 1;
if (pos == 1)
scrnprintsub(1,pos,0);
scrnprint(0,pos);
case 2:
pos--;
if (pos < 1)
pos = 4;
if (pos == 1)
scrnprint(0,pos);
case 6: //right = select
switch(pos)
case 1: // when menu position is one ISSUE STARTS HERE!!!
subpos = 1;
scrnprintsub(1,pos,1);
inputSelected = 0; //sets to 0 as initial condition
do
switch(LCDState()) //gets key press
case 2: //cycle through options
subpos--;
if (subpos < 1){subpos = 4;}
Serial.print(subpos);
scrnprintsub(1,subpos,1);
case 8: //cycle through options
subpos++;
if (subpos > 4){subpos = 1;}
case 6: //if input is selected, set inputSelected to current position, and print new value
inputSelected = subpos;
}while (inputSelected != 0); //exits this case when a value has been selected
delay(100);
}while(1==1);
void ClearLCD()
lcd.setCursor(0,0);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(" ");
delay(20);
/* Read the current state of the LCD buttons using the ADC */
int LCDState()
int ADC_Value;
int ADC_Button_State = 0;
ADC_Value = analogRead(0); /* Read the ADC */
/* If ADC reads above 1000 then assume no buttons have been pressed */
if (ADC_Value > 1000)
else /* If it was below 1000 then a button is pressed... */
/* If ADC reads between 0 & 49, then the RIGHT button has been pressed */
if (ADC_Value < 50)
ADC_Button_State = 6;
/* If ADC reads between 50 & 194, then the UP button has been pressed */
if (ADC_Value < 195)
ADC_Button_State = 8;
/* If ADC reads between 195 & 379, then the DOWN button has been pressed */
if (ADC_Value < 380)
ADC_Button_State = 2;
/* If ADC reads between 380 & 555, then the LEFT button has been pressed */
if (ADC_Value < 555)
ADC_Button_State = 4;
/* If ADC reads between 555 & 789, then the SELECT button has been pressed */
if (ADC_Value < 790)
ADC_Button_State = 1;
delay(150);
return ADC_Button_State;
Edit: problem is menu doesn't change to inputSelected, just stays on sub switch/case routine.
Many Thanks in advance
Sam
