LCD Menu instable
I am fighting with my menu that is controlled with 4 button.
If i go testing my sketch on the arduino than the sketch is not so stable.
I upload the sketch and the lcdItem give directly a valeu 8 and it must be 0.( row 64)
The code where i will control the loopconstrain on row 308 is the biggest problem.
There are now 2 open ends.
How can i change the code that it is working well?
#include <Wire.h>
#include <SPI.h>
const int  cs=8;
LiquidCrystal_I2C lcd(0x27,16,2);
const int buttonPinUp = 2;
const int buttonPinDown = 3;
const int buttonPinEsc = A0;
const int buttonPinEnter = 9;
const int Sensormicro = A2;
boolean LastValUp = true;
boolean LastValDown = true;
boolean LastValEsc = true;
boolean LastValEnter = true;
boolean autoEnabled = true;
int lcdItem = 0;
int lcdEdit = 0;
boolean timeEnabled[] = {false,false,false};
int timeHours[] = {0,0,0};
int timeMinutes[] = {0,0,0};
int Weight = 0;
byte Value_E1 = 150;
byte Value_E2 = 100;
int C_Day=25;
int C_Month=6;
int C_Year=12;
int C_Hour=14;
int C_Min=49;
int C_second=55;
byte lcdCharUpDown[8] = {
  0b00100,
  0b01110,
  0b11111,
  0b00000,
  0b00000,
  0b11111,
  0b01110,
  0b00100
void setup(){
  lcd.init();
  lcd.backlight();
  pinMode(buttonPinUp, INPUT);
  pinMode(buttonPinDown, INPUT);
  pinMode(buttonPinEnter, INPUT);
  pinMode(buttonPinEsc, INPUT);
void loop(){
if (lcdEdit == 0){
    lcdItem = loopConstrain(lcdUpDownControl(lcdItem),0,8);
  lcdButtonControl();
  lcdMenu();
  lcdEditValues();
void lcdButtonControl(){
  boolean ValEnter=digitalRead(buttonPinEnter);
  if (ValEnter !=LastValEnter){
    if (ValEnter==LOW){
      Serial.print("ENTER");
      lcd.clear();
      lcdEdit ++;
  LastValEnter=ValEnter;
  boolean ValEsc=digitalRead(buttonPinEsc);
  if (ValEsc !=LastValEsc){
    if (ValEsc==LOW){
      lcd.clear();
      lcdItem = 0;
  LastValEsc=ValEsc;
boolean lcdUpDownControl(int oldValue){
  boolean ValUp=digitalRead(buttonPinUp);
  if (ValUp !=LastValUp){
    if (ValUp==LOW){
       Serial.println("plus");
         LastValUp=ValUp;
         lcd.clear();
      return oldValue + 1;
  LastValUp=ValUp;
  boolean ValDown=digitalRead(buttonPinDown);
  if (ValDown !=LastValDown){
    if (ValDown==LOW){
        LastValDown=ValDown;
        lcd.clear();
          return oldValue - 1;
  return oldValue;
void lcdMenu(){
  switch (lcdItem){
  case 0:
    lcd.setCursor(0,0);
    if (autoEnabled){
      lcd.print("A ");
    else{
      lcd.print("M ");
    lcd.print("1:12:15");
    lcd.setCursor(0,1);
    lcd.print("Temp ");
    lcd.print("25");
    lcd.print(" C      ");
    delay(10);
  case 1:
    lcd.setCursor (0,0);
    lcd.print ("Time 1");
  case 2:
    lcd.print ("Time 2");
  case 3:
    lcd.print ("Time 3");
  case 4:
    lcd.print ("Weight");
  case 5:
    lcd.print ("Speed");
  case 6:
    lcd.print ("Set time");
  case 7:
    lcd.print ("Set date");
  case 8:
    lcd.print ("Sample run");
void lcdEditValues(){
  byte timeId = 0;
  lcd.setCursor (0,1);
  switch(lcdItem){
  case 0:
  lcdEdit = 0;
  case 1:
  case 2:
  case 3:
    timeId = lcdItem-1;
    if (timeEnabled[timeId]){
      lcd.print("on");
    else{
      lcd.print("off");
    if (lcdEdit == 1){
      lcd.print('\x00');
      timeEnabled[timeId] = loopConstrain(lcdUpDownControl(timeEnabled[timeId]), 0, 1);
    else{
      lcd.print(" ");
    lcd.print(timeHours[timeId]);
    if (lcdEdit == 2){
      lcd.print('\x00');
      timeHours[timeId] = loopConstrain(lcdUpDownControl(timeHours[timeId]),0,23);//constrain(, 0, 23);
    else{
      lcd.print(" ");
    lcd.print(":");
    lcd.print(timeMinutes[timeId]);
    if (lcdEdit == 3){
      lcd.print('\x00');
      timeMinutes[timeId] = loopConstrain(lcdUpDownControl(timeMinutes[timeId]), 0, 59);
    else{
      lcd.print(" ");
    if (lcdEdit == 4){
      lcdEdit = 0;
   case 4:
    lcd.print(Weight);
    if (lcdEdit == 1){
      lcd.print('\x00');
      Weight = loopConstrain(lcdUpDownControl(Weight), 0, 1000);
    if (lcdEdit == 2){
      lcdEdit = 0;
    case 5:
    lcd.print(Value_E2);
    if (lcdEdit == 1){
      lcd.print('\x00');
      Value_E2 = loopConstrain(lcdUpDownControl(Value_E2), 0, 255);
    if (lcdEdit == 2){
      lcdEdit = 0;
    case 6:
      lcd.print(C_Hour);
    if (lcdEdit == 1){
      lcd.print('\x00');
      C_Hour = loopConstrain(lcdUpDownControl(C_Hour), 0, 23);
     else{
      lcd.print(" ");
    lcd.print(":");
    lcd.print(C_Min);
    if (lcdEdit == 2){
      lcd.print('\x00');
      C_Min = loopConstrain(lcdUpDownControl(C_Min), 0, 59);
    if (lcdEdit == 3){
      SetTimeDate(C_Day,C_Month,C_Year,C_Hour,C_Min,C_second);
      lcdEdit = 0;
    case 7:
      lcd.print(C_Day);
    if (lcdEdit == 1){
      lcd.print('\x00');
      C_Day= loopConstrain(lcdUpDownControl(C_Day), 1, 31);
     else{
      lcd.print(" ");
    lcd.print("/");
    lcd.print(C_Month);
    if (lcdEdit == 2){
      lcd.print('\x00');
      C_Month = loopConstrain(lcdUpDownControl(C_Month), 1, 12);
         else{
      lcd.print(" ");
    lcd.print("/");
    lcd.print(C_Year);
    if (lcdEdit == 3){
      lcd.print('\x00');
      C_Year = loopConstrain(lcdUpDownControl(C_Year), 0, 99);
    if (lcdEdit == 4){
      lcdEdit = 0;
    case 8:
    lcd.print("Press enter to run");
    if (lcdEdit == 1){
      lcdEdit = 0;
int loopConstrain(int x,int a,int b){
if (x == a-1 || x ==255){
   return b;
 if (x == b+1){
   return a;
   Serial.print("x=");
  Serial.println(x);
  Serial.print("a=");
  Serial.println(a);
  Serial.print("b=");
  Serial.println(b);
return x;
int RTC_init(){
	  pinMode(cs,OUTPUT);
	  SPI.begin();
	  SPI.setBitOrder(MSBFIRST);
	  SPI.setDataMode(SPI_MODE3);
	  digitalWrite(cs, LOW);
	  SPI.transfer(0x8E);
	  SPI.transfer(0x60);
	  digitalWrite(cs, HIGH);
	  delay(10);
int SetTimeDate(int d, int mo, int y, int h, int mi, int s){
	int TimeDate [7]={s,mi,h,0,d,mo,y};
	for(int i=0; i<=6;i++){
		if(i==3)
			i++;
		int b= TimeDate[i]/10;
		int a= TimeDate[i]-b*10;
		if(i==2){
			if (b==2)
				b=B00000010;
			else if (b==1)
				b=B00000001;
		TimeDate[i]= a+(b<<4);
		SPI.transfer(i+0x80);
		SPI.transfer(TimeDate[i]);
String ReadTimeDate(){
	String temp;
	int TimeDate [7];
		if(i==3)
			i++;
		SPI.transfer(i+0x00);
		unsigned int n = SPI.transfer(0x00);
		int a=n & B00001111;
		if(i==2){
			int b=(n & B00110000)>>4;
			if(b==B00000010)
				b=20;
			else if(b==B00000001)
				b=10;
			TimeDate[i]=a+b;
		else if(i==4){
			TimeDate[i]=a+b*10;
		else if(i==5){
			int b=(n & B00010000)>>4;
			TimeDate[i]=a+b*10;
		else if(i==6){
			int b=(n & B11110000)>>4;
			TimeDate[i]=a+b*10;
		else{
			int b=(n & B01110000)>>4;
			TimeDate[i]=a+b*10;
	temp.concat(TimeDate[4]);
	temp.concat("/") ;
	temp.concat(TimeDate[5]);
	temp.concat("/") ;
	temp.concat(TimeDate[6]);
	temp.concat("  ") ;
	temp.concat(TimeDate[2]);
	temp.concat(":") ;
	temp.concat(TimeDate[1]);
  return(temp);
I'd recommend leaving the code that is working well alone, and fix the stuff that is not working well.
I'd also recommend that you put each { on a new line, and use Tools + Auto Format.
Judicious use of white space would be good.
Comments would, too. There is nothing that defines what that code is supposed to do. Of course, you also haven't told us what it actually does, or shown any serial output.
Good thing you found the problem before you wrote too much code.
