LCD menu problem
HI!
I have a problem with the LCD menu code. I should get the motor cycle adjusted via the LCD menu, the motor will start and the speed can be adjusted. But I don't get the cycle to work. I have a motor control Cytron MD10C R3 and for a cycle break I thought I could use an SSR relay. I found that LCD menu program on the curiousscientist.tech page meaning this is a cut and paste project.
:wink:
I have a problem with the LCD menu code. I should get the motor cycle adjusted via the LCD menu, the motor will start and the speed can be adjusted. But I don't get the cycle to work. I have a motor control Cytron MD10C R3 and for a cycle break I thought I could use an SSR relay. I found that LCD menu program on the curiousscientist.tech page meaning this is a cut and paste project. :
I like to listen to other ways to program similar functions.
The problem is menu2 at line 161 forward to line 181 because it is taken from the examples of Arduino. Otherwise the code works but that menu2 needs a wiser study of how to make it work. Menu2 item works on the LCD the values change and work ok but the relay does not work. The connections have been checked several times.
Thanks to all the helpers.
Here is the code:
//20x4 LCD
#include <LiquidCrystal_I2C.h> //SDA = B7[A4], SCL = B6[A5] STM32/[Arduino]
LiquidCrystal_I2C lcd(0x27, 20, 4);
#include "CytronMotorDriver.h"
CytronMD motor(PWM_DIR, 11, 12);  // PWM = Pin 3, DIR = Pin 4.
int menuCounter = 0; //counts the clicks of the rotary encoder between menu items (0-3 in this case)
int menu1_Value = 0; //value within menu 1
int menu2_Value = 0; //value within menu 2
int menu3_Value = 0; //value within menu 3
int menu4_Value = 0; //value within menu 4
bool menu1_selected = false; //enable/disable to change the value of menu item
bool menu2_selected = false;
bool menu3_selected = false;
bool menu4_selected = false;
//Note: if a menu is selected ">" becomes "X".
//Defining pins
//Arduino interrupt pins: 2, 3.
const int RotaryCLK = 2; //CLK pin on the rotary encoder
const int RotaryDT = 6; //DT pin on the rotary encoder
const int PushButton = 3; //Button to enter/exit menu
const int PAUSERELAY = 8;// the number of the LED pin
//Statuses for the rotary encoder
int CLKNow;
int CLKPrevious;
int DTNow;
int DTPrevious;
bool refreshLCD = true; //refreshes values
bool refreshSelection = false; //refreshes selection (> / X)
int relayState = LOW;             // relayState used to set the relay
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0;        // will store last time relay was updated
// constants won't change:
//const long interval = 1000 ;           // interval at which to blink (milliseconds)
  pinMode(2, INPUT_PULLUP); //RotaryCLK
  pinMode(6, INPUT_PULLUP); //RotaryDT
  pinMode(3, INPUT_PULLUP); //Button
  pinMode(9, OUTPUT);      // Pauserelay
  lcd.begin();                      // initialize the lcd
  lcd.backlight();
  lcd.setCursor(0,0); //Defining positon to write from first row, first column .
  lcd.print("Menu demo");
  lcd.setCursor(0,1); //Second row, first column
  lcd.print("Rotary encoder");
  lcd.setCursor(0,2); //Second row, first column
  lcd.print("Improved version");
  delay(2000); //wait 2 sec
  lcd.clear(); //clear the whole LCD
  printLCD(); //print the stationary parts on the screen
  //Store states of the rotary encoder
  CLKPrevious = digitalRead(RotaryCLK);
  DTPrevious = digitalRead(RotaryDT);
  attachInterrupt(digitalPinToInterrupt(RotaryCLK), rotate, CHANGE); //CLK pin is an interrupt pin
  attachInterrupt(digitalPinToInterrupt(PushButton), pushButton, FALLING); //PushButton pin is an interrupt pin
  if(refreshLCD == true) //If we are allowed to update the LCD ...
    updateLCD(); // ... we update the LCD ...
    //... also, if one of the menus are already selected...
    if(menu1_selected == true || menu2_selected == true || menu3_selected == true || menu4_selected == true)
     // do nothing
      updateCursorPosition(); //update the position
    refreshLCD = false; //reset the variable - wait for a new trigger
  if(refreshSelection == true) //if the selection is changed
    updateSelection(); //update the selection on the LCD
    refreshSelection = false; // reset the variable - wait for a new trigger
void rotate()
  //-----MENU1--------------------------------------------------------------
  if(menu1_selected == true)
  CLKNow = digitalRead(RotaryCLK); //Read the state of the CLK pin
  // If last and current state of CLK are different, then a pulse occurred
  if (CLKNow != CLKPrevious  && CLKNow == 1)
    // If the DT state is different than the CLK state then
    // the encoder is rotating in A direction, so we increase
    if (digitalRead(RotaryDT) != CLKNow)
      if(menu1_Value < 100) //we do not go above 100
        menu1_Value++;
        map(menu1_Value, 0, 100, 0, 255);
        motor.setSpeed(menu1_Value);  // Run forward at 50% speed.
        menu1_Value = 100;
        motor.setSpeed(0);  // Run forward at 50% speed.
      if(menu1_Value < 1) //we do not go below 0
          menu1_Value = 0;
      // Encoder is rotating B direction so decrease
      menu1_Value--;
  CLKPrevious = CLKNow;  // Store last CLK state
  //---MENU2---------------------------------------------------------------
  else if(menu2_selected == true)
      if(menu2_Value < 100) //we do not go above 100
        menu2_Value++;
        map(menu2_Value, 0, 100, 0, 1000);
        const long interval = menu2_Value ;           // interval at which to blink (milliseconds)
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (relayState == LOW) {
      relayState = HIGH;
    else {
      relayState = LOW;
    // set the relay with the relayState of the variable:
    digitalWrite(PAUSERELAY, relayState);
        menu2_Value = 100;
      if(menu2_Value < 1) //we do not go below 0
          menu2_Value = 0;
      // Encoder is rotating in B direction, so decrease
      menu2_Value--;
  //---MENU3---------------------------------------------------------------
  else if(menu3_selected == true)
      if(menu3_Value < 100) //we do not go above 100
        menu3_Value++;
        menu3_Value = 0;
      if(menu3_Value < 1) //we do not go below 0
          menu3_Value = 100;
      menu3_Value--;
  //---MENU4----------------------------------------------------------------
  else if(menu4_selected == true)
      if(menu4_Value < 100) //we do not go above 100
        menu4_Value++;
        menu4_Value = 0;
      if(menu4_Value < 1) //we do not go below 0
          menu4_Value = 100;
      menu4_Value--;
  else //MENU COUNTER----------------------------------------------------------------------------
      if(menuCounter < 3) //we do not go above 3
        menuCounter++;
        menuCounter = 0;
      if(menuCounter < 1) //we do not go below 0
          menuCounter = 3;
      // Encoder is rotating CW so decrease
      menuCounter--;
  //Refresh LCD after changing the counter's value
  refreshLCD = true;
void pushButton()
  switch(menuCounter)
     case 0:
     menu1_selected = !menu1_selected;  //we change the status of the variable to the opposite
     case 1:
     menu2_selected = !menu2_selected;
     case 2:
     menu3_selected = !menu3_selected;
     case 3:
     menu4_selected = !menu4_selected;
  refreshLCD = true; //Refresh LCD after changing the value of the menu
  refreshSelection = true; //refresh the selection ("X")
void printLCD()
  //These are the values which are not changing the operation
  lcd.setCursor(1,0); //1st line, 2nd block
  lcd.print("Menu 1"); //text
  lcd.setCursor(1,1); //2nd line, 2nd block
  lcd.print("Menu 2"); //text
  lcd.setCursor(1,2); //3rd line, 2nd block
  lcd.print("Menu 3"); //text
  lcd.setCursor(1,3); //4th line, 2nd block
  lcd.print("Menu 4"); //text
  lcd.setCursor(13,0); //1st line, 14th block
  lcd.print("cnt: "); //counts - text
void updateLCD()
  lcd.setCursor(17,0); //1st line, 18th block
  lcd.print(menuCounter); //counter (0 to 3)
  lcd.setCursor(9,0); //1st line, 10th block
  lcd.print("   "); //erase the content by printing space over it
  lcd.print(menu1_Value); //print the value of menu1_Value variable
  lcd.setCursor(9,1);
  lcd.print("   ");
  lcd.setCursor(9,1);
  lcd.print(menu2_Value); //
  lcd.setCursor(9,2);
  lcd.print("   ");
  lcd.setCursor(9,2);
  lcd.print(menu3_Value); //
  lcd.setCursor(9,3);
  lcd.print("   ");
  lcd.setCursor(9,3);
  lcd.print(menu4_Value); //
void updateCursorPosition()
  //Clear display's ">" parts
  lcd.setCursor(0,0); //1st line, 1st block
  lcd.print(" "); //erase by printing a space
  lcd.setCursor(0,1);
  lcd.print(" ");
  lcd.setCursor(0,2);
  lcd.print(" ");
  lcd.setCursor(0,3);
  lcd.print(" ");
  //Place cursor to the new position
  switch(menuCounter) //this checks the value of the counter (0, 1, 2 or 3)
    case 0:
    lcd.print(">");
    case 1:
    lcd.setCursor(0,1); //2nd line, 1st block
    lcd.print(">");
    case 2:
    lcd.setCursor(0,2); //3rd line, 1st block
    lcd.print(">");
    case 3:
    lcd.setCursor(0,3); //4th line, 1st block
    lcd.print(">");
void updateSelection()
  //When a menu is selected ">" becomes "X"
    lcd.print("X");
    lcd.print("X");
    lcd.print("X");
    lcd.print("X");
just simple advice
bool relayState = false;
very nice
No. relayState is used for digitalWrite() which takes LOW/HIGH, not true/false.
If you peek under the hood, you will see true == HIGH and false == LOW, but you aren't supposed to peek under the hood.
If you really want to save 1 byte of storage, you can do
char relayState = HIGH;
but why bother?
i see. i say nothing more.
a lot of code. hard to follow. could be table driven
