Hello, I've been battling with this problem for a while now and could really use some guidance.
I'm attempting to replace a REALLY OLD dot matrix display with a 7.0" inch 800x480 display from Adafruit that runs with an RA8875 driver board. I'm using an Arduino Mega.
The data displayed on the old screen is sent to it via one Serial line at 9600 baud. I have NO WAY of modifying that data coming in. All i can do is read the data and attempt to replicate it on my screen.
Theres a few special characters and commands that i've outlined in the code in my comments.
There's also a keypad to navigate the screen but that works indepndantly from the screen.
My program mostly works majority of the screens display perfectly but some screens miss some characters or leave characters from previous screens that were supposed to be overwritten with spaces but for some reason the spaces are written on the wrong lines. I'm almost certain the problem is with the LINE/COLUMN command and my use of "while (!Serial3.available())"
but i cant figure it out. Can anyone see anything wrong with this?
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_RA8875.h"
#define RA8875_INT 44
#define RA8875_CS 46
#define RA8875_RESET 48
#define Busy 27 //Signal that must be toggled to keep screen from sleeping(cant wake it up)
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
unsigned long startMillis; //timer for toggling busy
char SData; //Serial Data to be displayed
int CURRENTLINE = 0; //splitting my 800x480 LCD into 8 lines and 32 columns to match old screen
int CURRENTCOLUMN = 0;
int LINESTART[8] = {10, 60, 120, 180, 240, 300, 360, 420};
int COL[32];
int z = 0; //variable to fill my Column array
Serial3.begin(9600); //Display data
/* Initialize the display using 'RA8875_480x80', 'RA8875_480x128', 'RA8875_480x272' or 'RA8875_800x480' */
if (!tft.begin(RA8875_800x480)) {
while (1);
tft.displayOn(true);
tft.GPIOX(true); // Enable TFT - display enable tied to GPIOX
tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
tft.PWM1out(255);
tft.fillScreen(RA8875_BLACK);
/* Switch to text mode */
tft.textMode();
memset(COL, 0, sizeof(COL)); //filling column array
for (int i = 0; i < 32; i++)
COL[i] = z;
z += 25;
pinMode(Busy, OUTPUT);
digitalWrite(Busy, HIGH);
startMillis = millis();
if (Serial3.available() > 0)
SData = Serial3.read();
switch (SData)
case 0x13: //Command to move cursor to a new line
while (!Serial3.available()) {}
CURRENTLINE = Serial3.read(); // second byte is the line
case 0x11: //0x13 is always followed by 0x11 for column
CURRENTCOLUMN = Serial3.read(); // second byte is the column
tft.textSetCursor( COL[CURRENTCOLUMN], LINESTART[CURRENTLINE]); //set the cursor to the specified Line/Column
case 0x87: //Special case to old Screen, useless now. Sends 2 bytes after 0x87
Serial3.read(); // third byte
case 0xC: //Refresh screen command
tft.textColor(0xFBC0, RA8875_BLACK); //reset text color and size
tft.textEnlarge(2);
default:
if (SData == 0xFE) // Special character unsupported by my LCD so i convert it to ":"
tft.textWrite(":");
CURRENTCOLUMN = CURRENTCOLUMN + 1; //Increment Cursor
tft.textEnlarge(2);
tft.textWrite(&SData, 1); //Print Character to LCD
CURRENTCOLUMN = CURRENTCOLUMN + 1;//Increment Cursor
else if (millis() - startMillis >= 400)//toggle Busy every 400 ms
digitalWrite(Busy, LOW);
delayMicroseconds(5); //made delay as small as possible to avoid missing serial data
Sorry for the long post
