So I'm new to Arduino programming and I'm currently running into the issue where my display wont print what I've programmed it to after the first loop. After I use the reset button to reset the screen and lights the hardware just doesn't work the second time.
My setup is the attached file.
Thanks in advance!
Hardware Setup: arduino hosted at ImgBB — ImgBB
#include <LiquidCrystal.h>
// Define Orbital Switches
#define ORBIT0 A0
#define ORBIT1 A1
#define ORBIT2 A2
#define ORBIT3 A3
#define ORBIT4 A4
#define ORBIT5 A5
// Define Spectrum Lights
#define RED_STRIP 2
#define CYAN_STRIP 3
#define BLUE_STRIP 4
#define VIOLET_STRIP 5
#define NUM_PIXELS 8
Adafruit_NeoPixel RED = Adafruit_NeoPixel(NUM_PIXELS, RED_STRIP, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel CYAN = Adafruit_NeoPixel(NUM_PIXELS, CYAN_STRIP, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel BLUE = Adafruit_NeoPixel(NUM_PIXELS, BLUE_STRIP, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel VIOLET = Adafruit_NeoPixel(NUM_PIXELS, VIOLET_STRIP, NEO_GRB + NEO_KHZ800);
// Define LCD
#define RS 7
#define En 8
#define DB4 9
#define DB5 10
#define DB6 11
#define DB7 12
LiquidCrystal LCD(RS, En, DB4, DB5, DB6, DB7);
// Defining Power & Reset Button
#define POWER_SWITCH
#define RESET_SWITCH 6
// Declaring Variables
int delayval = 100;
int redColor = 0;
int greenColor = 0;
int blueColor = 0;
int initialOrbital, finalOrbital;
double lambda, E;
pinMode(RED_STRIP, OUTPUT);
pinMode(CYAN_STRIP, OUTPUT);
pinMode(BLUE_STRIP, OUTPUT);
pinMode(VIOLET_STRIP, OUTPUT);
pinMode(ORBIT0, INPUT);
pinMode(ORBIT1, INPUT);
pinMode(ORBIT2, INPUT);
pinMode(ORBIT3, INPUT);
pinMode(ORBIT4, INPUT);
pinMode(ORBIT5, INPUT);
pinMode(RESET_SWITCH, INPUT);
RED.begin();
CYAN.begin();
BLUE.begin();
VIOLET.begin();
LCD.begin(20, 4);
startProgram();
easterEgg();
void startProgram()
LCD.setCursor(0, 0);
LCD.print("Set Initial Orbital");
initialOrbital = getOrbital();
waitForAllClear();
LCD.println("Set Final Orbital");
finalOrbital = getOrbital();
while (initialOrbital == finalOrbital)
LCD.setCursor(0, 3);
LCD.println("Invalid Input!");
waitForAllClear();
displayOrbitals(initialOrbital, finalOrbital);
delay(5000);
LCD.clear();
if (finalOrbital == 2 && initialOrbital > finalOrbital)
displayLight(initialOrbital);
lambda = calcwavelength(initialOrbital, finalOrbital);
E = calcEnergy(lambda);
displayAnalysis(initialOrbital, finalOrbital, lambda, E);
reset();
LCD.clear();
int getOrbital()
int currentOrbital = -1;
while (currentOrbital < 0)
currentOrbital = checkButtonPressed();
return currentOrbital;
int checkButtonPressed()
delay(2000);
while (digitalRead(ORBIT0) == HIGH)
return 1;
while (digitalRead(ORBIT1) == HIGH)
return 2;
while (digitalRead(ORBIT2) == HIGH)
return 3;
while (digitalRead(ORBIT3) == HIGH)
return 4;
while (digitalRead(ORBIT4) == HIGH)
return 5;
while (digitalRead(ORBIT5) == HIGH)
return 6;
return (-1);
void waitForAllClear()
LCD.setCursor(0, 1);
LCD.print("Move the Electron");
while (digitalRead(ORBIT0) == HIGH || digitalRead(ORBIT1) == HIGH || digitalRead(ORBIT2) == HIGH ||
digitalRead(ORBIT3) == HIGH || digitalRead(ORBIT4) == HIGH || digitalRead(ORBIT5) == HIGH)
LCD.clear();
LCD.setCursor(0, 2);
void displayOrbitals(int initialOrbital, int finalOrbital)
LCD.clear();
LCD.print("Orbital 1: " + String(initialOrbital));
LCD.print("Orbital 2: " + String(finalOrbital));
double calcwavelength(int initialOrbital, int finalOrbital)
double R = 10973731.6;
double invni = initialOrbital * initialOrbital;
double invnf = finalOrbital * finalOrbital;
double nf = 1 / (invnf);
double ni = 1 / (invni);
double nDelta = nf - ni;
double invLambda = R * nDelta;
double lambda = 1e9 / invLambda;
return lambda;
double calcEnergy(double lambda)
double h = 6.62607004e-34;
double c = 299792458;
lambda = lambda * 1e-9;
double E = (h * c) / lambda;
E = 1e18 * E;
return E;
void displayAnalysis(int initialOrbital, int finalOrbital, double lambda, double E)
if (initialOrbital > finalOrbital)
LCD.clear();
LCD.print("Energy Emitted: ");
LCD.print(E);
LCD.setCursor(6, 1);
LCD.print(" aJ");
LCD.println("Wavelength Emitted: ");
LCD.print(lambda);
LCD.setCursor(6, 3);
LCD.print(" nm");
else if (initialOrbital < finalOrbital)
LCD.clear();
LCD.print("Energy Absorbed: ");
LCD.print(E);
LCD.print(" aJ");
LCD.println("Wavelength Absorbed: ");
LCD.print(lambda);
LCD.print(" nm");
void displayLight(int initialOrbital)
uint32_t red_high = RED.Color(255, 0, 0);
uint32_t cyan_high = CYAN.Color(0, 255, 255);
uint32_t blue_high = BLUE.Color(13, 31, 224);
uint32_t violet_high = VIOLET.Color(128, 17, 219);
if (initialOrbital == 3)
digitalWrite(RED_STRIP, HIGH);
for (int i = 0; i < NUM_PIXELS; i++)
RED.setPixelColor(i, red_high);
RED.show();
else if (initialOrbital == 5)
digitalWrite(BLUE_STRIP, HIGH);
BLUE.setPixelColor(i, blue_high);
BLUE.show();
else if (initialOrbital == 4)
digitalWrite(CYAN_STRIP, HIGH);
CYAN.setPixelColor(i, cyan_high);
CYAN.show();
else if (initialOrbital == 6)
digitalWrite(VIOLET_STRIP, HIGH);
VIOLET.setPixelColor(i, violet_high);
VIOLET.show();
void reset()
boolean flag = checkReset();
while (flag)
// Resetting the lights & LCD
LCD.clear();
uint32_t low = RED.Color(0, 0, 0);
BLUE.setPixelColor(i, low);
RED.setPixelColor(i, low);
CYAN.setPixelColor(i, low);
VIOLET.setPixelColor(i, low);
RED.show();
CYAN.show();
BLUE.show();
VIOLET.show();
boolean checkReset()
while (digitalRead(RESET_SWITCH) == HIGH)
return false;
return true;
void easterEgg()
boolean check = checkEasterEgg();
while (check)
while (digitalRead(ORBIT0) == HIGH && digitalRead(ORBIT1) == HIGH && digitalRead(ORBIT2) == HIGH &&
digitalRead(ORBIT3) == HIGH && digitalRead(ORBIT4) == HIGH && digitalRead(ORBIT5) == HIGH)
setColor();
RED.setPixelColor(i, RED.Color(redColor, greenColor, blueColor));
CYAN.setPixelColor(i, CYAN.Color(redColor, greenColor, blueColor));
BLUE.setPixelColor(i, BLUE.Color(redColor, greenColor, blueColor));
VIOLET.setPixelColor(i, VIOLET.Color(redColor, greenColor, blueColor));
RED.show();
CYAN.show();
BLUE.show();
VIOLET.show();
delay(delayval);
if (i == NUM_PIXELS)
i = 0;
setColor();
LCD.clear();
LCD.setCursor(7, 0);
LCD.print("DESIGN");
LCD.setCursor(8, 0);
LCD.print("TEAM");
LCD.setCursor(10, 2);
LCD.print("1");
LCD.setCursor(7, 3);
LCD.print("BITCHES");
reset();
boolean checkEasterEgg()
return false;
return true;
void setColor()
redColor = random(0, 255);
greenColor = random(0, 255);
blueColor = random(0, 255);
Serial.print("red: ");
Serial.println(redColor);
Serial.print("green: ");
Serial.println(greenColor);
Serial.print("blue: ");
Serial.println(blueColor);
