My problem is that the LCD is not displaying a variable as a number, it's instead displaying a character.
Depending on the value it displays a different character. It displays variable named "highscore" properly but it is not displaying "score" and "raund" properly. Help is much appreciated.
EDIT: If I create a custom character(aka a proper number) to the position 0, 1, 2, 3 it displays those numbers correctly.
My code:
#include <LiquidCrystal.h>
#include <EEPROM.h>
LiquidCrystal lcd(12, 11, 5, 15, 3, 2);
int raund = 0;
int z;
int y;
int x;
int playsequence = 0;
int sequence[30] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
int neu = 1;
int gameend = 0;
int receivesequence = 0;
int buttonpresscount = 0;
int score = 1; //String
int highscore;
//LED ports
int sinineled = 4;
int punaneled = 9;
int kollaneled = 10;
int rohelineled = 14;
//Switches
int sinineluliti = 8;
int punaneluliti = 7;
int kollaneluliti = 13;
int rohelineluliti = 6;
int luliti[4] = {
sinineluliti, punaneluliti, kollaneluliti, rohelineluliti};
int led[4] = {
sinineled, punaneled, kollaneled, rohelineled};
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("Maluvillak");
lcd.setCursor(0, 1);
highscore = EEPROM.read(1);
lcd.print("Parim skoor:");
lcd.setCursor(14, 1);
lcd.print(highscore);
pinMode(luliti[0], INPUT);
pinMode(led[0], OUTPUT);
pinMode(luliti[1], INPUT);
pinMode(led[1], OUTPUT);
pinMode(luliti[2], INPUT);
pinMode(led[2], OUTPUT);
pinMode(luliti[3], INPUT);
pinMode(led[3], OUTPUT);
digitalWrite(led[0], HIGH); //Random test to indicate it restarted
delay(55);
digitalWrite(led[1], HIGH);
digitalWrite(led[0], LOW);
delay(55);
digitalWrite(led[2], HIGH);
digitalWrite(led[1], LOW);
delay(55);
digitalWrite(led[3], HIGH);
digitalWrite(led[2], LOW);
delay(55);
digitalWrite(led[3], LOW);
Serial.begin(9600); //Serial communication
delay(2000);
void loop(){
if(neu==1){ //Generate a new number to the sequence
sequence[raund]= random(4);
playsequence = 1;
neu= 0;
lcd.setCursor(9, 0);
lcd.write("Lvl:");
lcd.setCursor(13, 0);
lcd.write(raund); //BUG
delay(250);
if(playsequence==1){
neu = 0;
Serial.println(raund);
if(raund > 0){
for(x = 0;x < raund+1; x++){
lcd.setCursor(15, 0);
Serial.print("Iks:");
Serial.println(x);
digitalWrite(led[sequence[x]], HIGH);
delay(200);
digitalWrite(led[sequence[x]], LOW);
delay(200);
Serial.println(x);
if(x < raund){ //End sequence playing if played enough
receivesequence = 1;
playsequence = 0;
buttonpresscount=0;
delay(250);
if(raund == 0){ //Rough patch to make it play the sequence when it's the first round
digitalWrite(led[sequence[0]], HIGH);
delay(200);
lcd.write("Skoor: ");
digitalWrite(led[sequence[0]], LOW);
lcd.setCursor(7, 0);
lcd.write(score);
delay(200);
playsequence = 0;
buttonpresscount=0;
if(receivesequence==1 && playsequence == 0){
for(z = 0; z < 4; z++){
if(z == 4){
z=0;
if(digitalRead(luliti[z]) == HIGH){
Serial.println(z);
digitalWrite(led[z], HIGH);
if(round!=0){
if(sequence[buttonpresscount]==z){
buttonpresscount++;
score++;
delay(300);
else{
receivesequence=0;
lcd.clear();
lcd.setCursor(7, 1);
lcd.write(score);
else{
if(sequence[0] == z){
score++;
receivesequence=0;
delay(200);
digitalWrite(led[z], LOW);
if(buttonpresscount == raund+1 && raund != 0){ //Right sequence was entered
receivesequence=0;
neu=1;
raund++;
buttonpresscount=0;
else if(buttonpresscount == 1 && raund == 0){ //Right button was pressed
receivesequence=0;
raund++;
neu=1;
Serial.print(buttonpresscount);
buttonpresscount==0;
if(gameend==1){
if(score > highscore){
EEPROM.write(1, score);
