LCD not functioning properly
floresta:
Try reading all of reply #1.
Don
I did. Have you had a chance to read reply #9 or reply #11?
I agree with your reply number one that the lcd and thermocouple must be working. I also agree the code must be an issue. Here is a copy of the example code that you can download from the ladyada example:
  This is an example for the Adafruit Thermocouple Sensor w/MAX31855K
  Designed specifically to work with the Adafruit Thermocouple Sensor
  ----> https://www.adafruit.com/products/269
  These displays use SPI to communicate, 3 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <SPI.h>
#include <Wire.h>
#include "Adafruit_MAX31855.h"
#include <LiquidCrystal.h>
// Example creating a thermocouple instance with software SPI on any three
// digital IO pins.
#define MAXDO   3
#define MAXCS   4
#define MAXCLK  5
// Initialize the Thermocouple
Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO);
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
   #define Serial SerialUSB
#endif
  #ifndef ESP8266
    while (!Serial);     // will pause Zero, Leonardo, etc until serial console opens
  #endif
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.clear();
  lcd.print("MAX31855 test");
  // wait for MAX chip to stabilize
  // basic readout test, just print the current temp
   lcd.clear();
   lcd.setCursor(0, 0);
   lcd.print("Int. Temp = ");
   lcd.println(thermocouple.readInternal());
   Serial.print("Int. Temp = ");
   Serial.println(thermocouple.readInternal());
   double c = thermocouple.readCelsius();
   lcd.setCursor(0, 1);
   if (isnan(c))
     lcd.print("T/C Problem");
     lcd.print("C = ");
     lcd.print(c);
     lcd.print("  ");
     Serial.print("Thermocouple Temp = *");
     Serial.println(c);
