I have a board made ??with a AtMega 328
My display is permanently connected to Port C..
I would like to write the program with the Arduino IDE and transmitted, would the output for the LCD, which is in the Liquid Cristal fix written to Port B Port C put on.
Have tried the Librarie. H. Ccp to c rewrite, but unfortunately that alone seems not to be enough.
Can anyone one of you give a hint what else I have to do?
Unfortunately that tutorial does not really describe how to use different pins. Instead it implies that you must use the pins that they are using by stating: "To wire your LCD screen to your Arduino, connect the following pins: ...."
