Lcd on the mega 2560
I am having trouble getting my lcd screen to work. Right now I want to have both a 4x4 keypad and an lcd screen plugged into my arduino mega 2560 but only my keypad works. Here is my wiring and code for this project. On the display I only see white boxes on my lcd screen. Many tutorials I have seen mentioned using the first thirteen pins only for the lcd, but I cannot do that with the keypad as well. Is there a way to wire the lcd just using the side pins? Or is this just a problem with my code?
for lcd
VSS = GND
VDD = 5v
VO = pin 22
RS = pin 24
RW = pin 26
E = pin 36
D4 = pin 28
D5 = pin 30
D6 = pin 32
D7 = pin 34
A =5v
K = GND
for keypad (going from left to right)
pin 2
pin 3
pin 4
pin 5
pin 6
pin 7
pin 8
pin 9
here is the code
#include <LiquidCrystal.h>
#include <Keypad.h> //libraries
static int count = 0; //variable used as first number
unsigned long lastTime = millis();
unsigned long wait = 10000;
int rs=24, en=36, d4=28, d5=30, d6=32, d7=34;
LiquidCrystal lcd(rs,en,d4,d5,d6,d7);
const byte ROWS = 4;
const byte COLS = 4;
bool blinking = false;
int buttonState=0;
int lastButtonState=0;
int buttonPushCounter =0;
int memory;
  void partLoc(){
      lcd.setCursor(7,1);
  void fabLoc(){
      lcd.setCursor(11,0);
  void clearScreen(){
      lcd.print("     ");
  void countUp(){
      count++;
      partLoc();
      clearScreen();
        partLoc();
      lcd.print(count);
        for (int i = 0; i <= 16; i++) {
          blinking=false;
            lcd.setCursor(i,1);
          tone(52,2200);
          delay(100);
          noTone(52);
  void countDown(){
      if(count!=0){
          count--;
          partLoc();
        clearScreen();
          partLoc();
        lcd.print(count);
            partLoc();
            lcd.print(count);
            blinking=false;
              lcd.setCursor(i,1);
                tone(52,2100);
          delay(100);
          noTone(52);
char hexaKeys [ROWS][COLS] ={
        {'1','2','3','A'},
        {'4','5','6','B'},
        {'7','8','9','C'},
        {'*','0','#','D'}
byte rowPins[ROWS] = {9, 8, 7, 6};
byte colPins[COLS] = {5, 4, 3, 2};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
  analogWrite(22,60);
  pinMode (52,OUTPUT);
  pinMode(51, OUTPUT);
  pinMode(13,INPUT);
  lcd.begin(16, 2);
  lcd.print("Fab Cell #");
  lcd.setCursor(0,1);
  lcd.print("Part #");
  lcd.blink();
void loop(){
  int sensor = digitalRead(53);
  unsigned long timeNow = millis();
  buttonState = digitalRead(53);
  if (buttonState != lastButtonState) {
    if (buttonState == 1)  {
      buttonPushCounter++;
      //Serial.println("off");
      if (timeNow - lastTime > wait){ // adds delay after the count up but allows for input during the delay.  delay will not stop the rest of the program from running
      countUp();
      Serial.println(count);
      lastTime=timeNow;
  lastButtonState = buttonState;
  char customKey = customKeypad.getKey();
  if (blinking){
    lcd.blink();
  //Switchcase Statements
  switch (customKey){
    case 'C':
      countUp();
    case 'D':
    countDown();
    case 'B':
      fabLoc();
      clearScreen();
      fabLoc();
      blinking = true;
          tone(52,2200);
          delay(100);
          noTone(52);
  // Allows button input from buttons 0 - 9
  if ((customKey>='0') && (customKey <= '9')){
      lcd.print(customKey);
          blinking=false;
            lcd.setCursor(i,1);
          tone(52,2000);
          delay(100);
          noTone(52);
  //When A is pressed displays the most recently cleared number
    if (customKey=='A'){
        blinking=false;
          lcd.setCursor(i,0);
        blinking=false;
          lcd.setCursor(i,1);
          Serial.println(memory);
          lcd.setCursor(14,1);
          lcd.print(memory);
          delay(3000);
          lcd.setCursor(8,1);
          lcd.print("          ");
  //When # is pressed the count resets
    if (customKey=='#'){
      memory = count;  //stores the cleared value
      count=0;
      Serial.println("reset");
      lcd.setCursor(6,1);
      lcd.print("     ");
      partLoc();
      lcd.print(count);
      blinking=false;
        lcd.setCursor(i,1);
         tone(52,1200);
          delay(100);
          noTone(52);
Have you tried the "HelloWorld" example in File->Examples->LiquidCrystal in the IDE, but modified for your pins with just your LCD connected?
Which LCD do you have? IS its driver chip an Hitachi HD44780?
Make a new test-sketch for just the display. Find a tutorial for the display. For example this one: https://docs.arduino.cc/learn/electronics/lcd-displays
Some displays need a resistor for the backlight, some have a internal resistor.
I suggest to add a resistor of 220Ω.
The "VO" should be connected with a resistor to GND or with a potentiometer to GND. Start with a value of 470Ω.
The R/W pin is tied to GND.
Then it should work. This is a simulation: https://wokwi.com/projects/338884541878895186
