LCD pin converter pcb's
I'm playing about with I2C backpacks for LCD's, and i can easily and cheaply buy ones that have a row of 16 pins in a single row, which obviously i can solder directly onto a LCD with the 16 pins at the top (or fit plugs n sockets)
But most of my LCD's have the pins mounted on the side of the PCB in a 2 x 8 configuration,
ATM i'm making up wired adaptors, but i have seen PCB's that convert 1x16 to 2x8 pin, they were sold on alliexpress i think, but i can't find them again.
They are a small L shaped PCB, a 2x8 through hole arrangement on the short side of the L, and a 1x18 arrangement on the long side, double sided board, you just solder pin headers to them,
Does anyone else know what i'm talking about? and have a link to where i can buy a few?, ideally in the uk... as shipping things here is a pain atm.
I know i could design some, but i can only etch single sided pcb's reliably, and they need to be double sided to be compact in the L shape, which puts the I2C backpack parallel to the LCD as if it was connected to a 1x16 pin LCD.
gazz292:
You can design single-layer and your product is cheaper ...
(use some jumper wire for closed path of tracks for complete your routing)
This topic was automatically closed after 120 days. New replies are no longer allowed.
