Hello, first post so go easy on me. I've checked similar topics but no solution so far.
Initially, I had the problem that the LCD wouldn't print the analogue data. This was the code I had:
// include LCD library
#include <LiquidCrystal.h>
// define constants for wet and dry sensor
const int dry = 595; // value for dry sensor
const int wet = 239; // value for wet sensor
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
Serial.begin(9600); // set serial monitor so values can be monitored via IDE
// set up LCD pins as follows (also see: https://www.arduino.cc/en/Tutorial/LibraryExamples/HelloWorld for setup of LCD):
// LCD RS pin to digital pin 12
// LCD Enable pin to digital pin 11
// LCD D4 pin to digital pin 5
// LCD D5 pin to digital pin 4
// LCD D6 pin to digital pin 3
// LCD D7 pin to digital pin 2
// LCD R/W pin to GND
// LCD VSS pin to GND
// LCD VCC pin to 5V
// LCD LED+ to 5V through a 220 ohm resistor
// LCD LED- to GND
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2; // define pins corresponding with the above setup
LiquidCrystal lcd(rs, en, d4, d5, d6, d7); // define which pins on the LCD are being used
lcd.begin(16, 2); // set up the LCD's number of columns and rows
lcd.print("Soil Moisture: "); // Print a message to the LCD.
int sensorVal = analogRead(A0); // output analogue value as integer
int percentageHumididy = map(sensorVal, wet, dry, 100, 0); // set analogue value as percentage between 0% and 100%
Serial.print(percentageHumididy); // print output
Serial.println("%"); // add "%" sign after output to display as percentage
// SO FAR, THIS PRINTS VALUES IN THE SERIAL MONITOR. NOW WE HAVE TO PRINT TO THE LCD. Above, LCD library should be included in program.
lcd.setCursor(0, 1); // set the LCD cursor to column 0, line 1
lcd.print(percentageHumididy); // print the sensor value on LCD:
lcd.println("%"); // add "%" sign after output to display as percentage
delay(100); // restart loop after 1 second
I moved the lines referring to LCD from setup to loop and that fixed it, so now the code I have is:
LiquidCrystal lcd (12, 11, 10, 5, 4, 3, 2);
// LCD LED- to GND
Serial.println('%'); // add "%" sign after output to display as percentage
lcd.println('%'); // add "%" sign after output to display as percentage
And this works but it's sloppy. I don't understand why it works in loop but not setup. Surely it would be neater to have the constants defined in setup?
