lcd.print instead of serial.print
hello everyone
i am using a gsm shield to send some variables to my website through AT commands and the sketch is full of myserial.print functions etc. In my project i need to show all this information (and to read from a keypad instead of serial monitor), in an LCD1602 screen. Can anyone tell me if this is possible?
Thanks in advance.
Within the limitations of a screen 16 characters wide and 2 lines deep, probably, depending on the availability of pins to drive the LCD and read the keypad.
Have you got an LCD screen and keypad ?
Yes i got these
http://eud.dx.com/product/i2c-iic-lcd-1602-display-module-with-white-backlight-4-pin-cable-for-arduino-raspberry-pi-844374741
http://eud.dx.com/product/3x4-matrix-12-key-membrane-switch-keypad-keyboard-844117718
I dont mind if i have to clear the lcd as many times it needs. i just need to make this work.
Which Arduino are you using, what else is connected to it and which pins are being used ?
Have you managed to write to the LCD and read from the keypad ?
i am using Arduino Mega and i 've connected a gsm shield, an nRf24L01+ module, a 2channel relay, the lcd and the leyboard. So far my project was fully functional. I was able to print data to the screen as well as read keys from keypad.
The problem is that i want the output info of the AT commands as well as the httpread requests to print in my lcd instead of the serial monitor.
