lcd.print() two decimal places
Hello, I am trying to get the arduino to print to a precision of 2 decimal places.
Here is a slimmed down example of what my code looks like.
sensorValue = analogRead(sensorPin);
sensorValuePercentage = (sensorValue - 23) / 10;
lcd.print(sensorValuePercentage);
See if your LCD library implements the sprintf() method.
Thank you, I have been looking into float but cannot find a good tutorial on how to properly use it. All of my attempts so far have failed...
Do you have a good example?
I have seen that page. Cannot seem to implement it correctly :frowning:
This is the code i am using. It is simple enough.
#include <LiquidCrystal.h>
LiquidCrystal lcd(52, 53, 50, 51, 48, 49);
int sensorPin = A0;
int ledPin = 13;
int sensorValue = 0;
int sensorValuePercentage = 0;
  pinMode(ledPin, OUTPUT);
  lcd.clear();
  lcd.begin(20, 4);
  lcd.print("... loading");
  delay(200);
    digitalWrite(ledPin, HIGH);
    delay(sensorValue);
    digitalWrite(ledPin, LOW);
    delay(sensorValue);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Potentiometer Value");
  lcd.setCursor(0, 1);
  lcd.print(sensorValue);
  lcd.setCursor(5, 1);
  lcd.print("ohms");
  lcd.setCursor(0, 2);
  lcd.setCursor(5, 2);
  lcd.print("%");
NEVERMIND, I figured it out. Thanks for the help!
Here is the modified code in case someone else has a similar issue...
int sensorPin = A0;
int ledPin = 13;
float sensorValuePercentage;
  lcd.clear();
  lcd.begin(20, 4);
  delay(200);
    sensorValuePercentage = (float)(sensorValue - 23) / 10;
    delay(sensorValue);
    delay(sensorValue);
  lcd.clear();
  lcd.print("ohms");
  lcd.print("%");
Thinking outside the box you could use an integer to hold the value multiplied by 100, then print the value / 100 followed by a decimal point followed by the value mod (%) 100.
Example
301.34 would become 30134. 30134 / 100 in integer maths would become 301 and 30134 mod 100 would become 34.
pluggy:
Example
... which is what the Print::print(double n, int digits) method that the lcd library contains does.
