LCD printing vars??
Hi all, im newish to arduino and for the life of me cannot get this to work.
Ive worked quite a bit on my project now and all im trying to do is print a number + string to the LCD screen.
The number is an int and upto now all ive done is lcd.print(numberVar+" string")
But instead now i want the string to be a variable, but i cannot get it to compile.
Ive tring char,char* & string to declare the string. but all i get is:
invalid operands of types 'const char*' and 'char [4]' to binary 'operator+'
the above error is with the string declared as:
char currentUnit[] = "C";
and the lcd print as:
lcd.print(currentVal+" "+currentUnit);
if i change the lcd print to: lcd.print(currentVal+" C"); it works fine?
what am i doing wrong?
thanks Andy
How would you like the Arduino to ADD these values? That's what the + operator does.
lcd.print(currentVal);
lcd.print(" ");
lcd.print(currentUnit);
ok, i see that but i thought the + operator “concentates” strings?
If obviously it does, how do you concentate string variables?
Andy
Each constant or variable needs its own print statement. PaulS showed you the correct code.
Edit: typo...
but i thought the + operator "concentates" strings?
It is an operator in the String class, too. A String is not the same as a string. A string is a NULL terminated array of chars. There is no operator to concatenate strings. There is a function, strcat(), that can.
Ok thanks, ive implimeted it as in your code and that works great.
Thanks Andy
