As i understand i should use the TTL RXD pin on the lcd
No from that data sheet you need to connect it to a USB host, like a PC. The arduino does not act as a USB host. I think you have bought the wrong board because it looks like it contains a USB to serial bridge and you just want a straight serial input display. When you have one you connect it to the TX as you are transmitting data. The RX is for receiving data.
Thanks for input, if you look at this picture of it:
It is some inputs on the back, i tried soldering wires on to them, and in the PDF it states "NOTE: If other serial ports are used to control Edition III, please enter start command (command in the 12th row) before power on"
How do i enter this (0xFE,0x53,0x75,0x72,0x65) and i dont know if its HEX/BYTE
Like this?
int thisByte;
thisByte = (0xFE,0x53,0x75,0x72,0x65);
Serial.print(thisByte, BYTE);
I think tat refers to the illustration where COM port 4 is used on the PC, if you use another one then this needs to be set up before you power on. To me that means it sends some stuff as well.
The TX data line on the board should be connected to the TX data on the arduino and the RX data line on the board to the RC line on the arduino.
I don't think you can do:-
an int is two bytes and you are trying to cram four bytes into it.
Then when you print it as a byte it cuts it down to one.
just print the bytes one at a time.
i'd rather you use a serial lcd there alot easier to deal with then the parellel ones but using the serial programmer for the parellel lcd should make ur life easy.
i have a qustion on the topic as well ..
will i tried connecting the arduion tx pin to a serial Lcd and sending chars to it but it didnt work at all.
with the mega it worked fine all i had to do was serial1.print and text and it took it out to the lcd
i coudlnt get the serial to work on the deminilova.
if i used any other pin do i need to have a ttl to rs232 converter ?? for the data to make since ??
speaking of serial as well i have another qustion am sorry am filled with qustions. >_<
i have manged to send data out to the lcd and am really hoping u can answer me this becuase i've asked sevral ppl today and no one seems to know
If you are getting aaaaaabbbbbbccccdddd when you type abcd then you are not waiting for a new character to arrive before you go round the loop again and print.
What problem exactly do you have and what set up are you using, you seem to have hijacked this dead thread.
hooo, no.. i'm a step behind
i still can't print
tryed both ttl and rs232 connector i can see the led blink (in one case)but the display doesn't react.
i think because of a wrong inizialization string but i'm unsure...
(same setup same lcd same arduino duemilanove)
i have the same display you can see in the pictures above, i've soldered a connector to the ttl port, and i've connected tx from the display to arduino pin 1 and rx from the display to the pin 0 of arduino.
when i send something i can see the led blinking on the lcd but nothing more... i'm stuck at the boot screen
That sounds the wrong way round. RX is an input on the arduino (pin 0) and should be connected to an output so I would assume that is a TX on the module (although these things can be defined the other way round).
Because the regular serial port is being used by the USB / serial chip and you often get a conflict when you try and use it for something different without disconnecting it first.
I assume you have not disconnected it, it involves removing two surface mount resistors.
haa, i didn't know .
so it can't work even if i disconnect the usb cable, give to arduino an external psu and push the reset button?
I'll try this code: #include <SoftwareSerial.h> #define rxPin 6 // software Rx pin (connect to Tx on LCD) #define txPin 7 // software Tx pin (connect to Rx on LCD)
// set up a new serial port
SoftwareSerial swSerial = SoftwareSerial(rxPin, txPin);
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
// set the data rate for the SoftwareSerial port
swSerial.begin(9600);
// and set the date rate for the real serial port
delay(100); // (can't use port immediately?)
startLCD();
swSerial.print("Hello, world!");
// retransmit bytes read from the computer to LCD
if (Serial.available() > 0) {
byte inchar = Serial.read();
swSerial.print(inchar);
