LCD problems
hey guys, i hooked up a 16x2 lcd, and i cant get it to work the way it should!
it only displays what i write in the void setup, if i try anything in void loop it has no effect
here is my code:
//Code by Dusan
//This code is public and open source
//Credits: BARRAGAN, JEREMY BLUM
#include <Servo.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(5,7,8,9,10,11);
Servo servo;
int pos;
float tempC;
int light;
int lightPin = 5;
int tempPin = 2;
int relay = 2;
int reading;
int buzzer = 4;
int i;
void setup ()
  lcd.begin(16,2);
  servo.attach(6);
  pinMode(relay, OUTPUT);
  pinMode(lightPin, INPUT);
  pinMode(buzzer, OUTPUT);
  for(int i=1; i <= 92; i++)
    Serial.println(i);
//loop startup, sensor readings and loop sequencing
  analogRead(lightPin);
  delay(10);
  light = map((analogRead(lightPin)),750,1023,255,0) ;
  delay(10);
  analogRead(tempPin);
  delay(10);
  reading = analogRead(tempPin);
  tempC = (5.0*reading*100)/1023;
  Serial.print("Temperature = ");
  Serial.print(tempC);
  Serial.println(" C");
  Serial.print("Light level = ");
  Serial.println(light);
  //first IF statement
  if(light > 100)
    digitalWrite(buzzer, HIGH);
    delay(100);
    digitalWrite(buzzer, LOW);
 //Seconf IF Statement
 if(i <= 46)
   digitalWrite(relay, HIGH);
   Serial.print("Relay State = ");
   Serial.println("ON");
   digitalWrite(relay, LOW);
   Serial.print("Light Relay State = ");
   Serial.println("OFF");
 if(i > 0)
  lcd.setCursor(0,2);
  delay(10);
  lcd.write(tempC);
  lcd.setCursor(0,1);
  lcd.write("Temperature");
  lcd.write("error");
 if(i == 10 || i == 20 || i == 30 || i == 40 || i == 50 || i == 60 || i == 70 || i == 80 || i == 90)
   delay(100);
   delay(150);
   delay(100);
   delay(150);
   delay(100);
   delay(150);
   delay(100);
   for(pos = 90 ; pos < 180; pos += 1)
     servo.write(pos);
     delay(15);
  for(pos = 180; pos >= 90; pos -= 1)
     servo.write(pos);
     delay(15);
     Serial.println("servo pause");
   Serial.println(" ");
 delay(5000);
what am i doing wrong?
Try lcd.print instead of write.
soved it, it was an error in the code, i defined a pin as output that i had used before geting the lcd. after deleting that it works fine now, thanks!
