LCD programming (beginner)
Hello,
I'm just starting out on my Arduino and programming journey and I'm having a wee bit of trouble getting one of the test Sketches from the book "Getting started with Sketches" to work.
I'm doing the "USB message board" using the LCD hat with 6 buttons on it. I typed the code in and keep getting these error messages:
"Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
C:\Users\sketch_jan03a_usb_message_test_not_working\sketch_jan03a_usb_message_test_not_working.ino: In function 'void loop()':
sketch_jan03a_usb_message_test_not_working:34:11: error: expected '}' before 'else'
sketch_jan03a_usb_message_test_not_working:36:19: error: 'ch' was not declared in this scope
lcd.write(ch);
C:\Users\Adam\Desktop\Arduino Test Sketches\sketch_jan03a_usb_message_test_not_working\sketch_jan03a_usb_message_test_not_working.ino: At global scope:
sketch_jan03a_usb_message_test_not_working:39:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences."
Not sure where I went wrong.
Here is my code:
#include <LiquidCrystal.h>
// lcd(RS, D4, D5, D6, D7)
LiquidCrystal lcd (8,9,4,5,6,7);
int numRows = 2;
int numCols = 16;
lcd.begin(numRows, numCols);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Arduino");
lcd.setCursor(0,1);
lcd.print("Rules");
if (Serial.available() > 0)
char ch = Serial.read();
if (ch == '#')
lcd.clear();
else if (ch== '/');
//new line
lcd.setCursor(0,1);
lcd.write(ch);
The error messages give you the line number and a position location on that line where the error was detected. Have you attempted to correct the errors?
Paul
else if (ch== '/');
You don't need the ;
For future posts please put code in code tags (<> in the edit toolbar). This prevents the forum posting software from interpreting combinations of characters into smileys, etc. and makes it easier to read.
