Hi, I got this screen attached to my uno. The full code is at the bottom of the link https://arduino-info.wikispaces.com/LCD-Pushbuttons
I want to display a starting value of 25g on the screen and then when I:
- Push the up button - I want it to add 5g to the start value and display this (and then wait for new input)
- Push the down button - remove 5g (and wait for new input) So same solution as in 1.
- Push select - Move on in the code.
My question and the problem, can I somehow perform an action when a button is pressed and then stay in the switch? Or should I use a different approach.
switch (lcd_key) // depending on which button was pushed, we perform an action
case btnRIGHT:
lcd.print("RIGHT ");
case btnLEFT:
lcd.print("LEFT ");
case btnUP:
lcd.print("UP ");
case btnDOWN:
lcd.print("DOWN ");
case btnSELECT:
lcd.print("SELECT");
case btnNONE:
lcd.print("NONE ");
}/* --(end switch )-- */
