lcd pushbuttons with ds1307
Hi all, i'm facing difficulty with this program, my third pushbutton can't seem to work. my original program is that the first button is an increment button. the second button is a decrement button. my third button is supposed to be the confirm/set button. when the first time the third button is pressed, the hour will be saved, then when the second time the third button is pressed, it will be saved into the min. but i cant seem to enter my third button loop and also, i can't seem to display my numbers at the correct place as well, even after setting the setCursor.
please help me, i really need help);
and this is my full code
#include <LiquidCrystal.h>
#include <Wire.h>
#include <DS1307.h>
const int  buttonPin1 = 16;    // the pin that the pushbutton is attached to the increment button
const int  buttonPin2 = 17;    // the pin that the pushbutton is attached to the decrement button
const int  Setbutton3 = 18;    // the pin that the pushbutton is attached to set/confirm button
const int ledPin = 13;       // the pin that the LED is attached to
int i = 0;
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonSetCounter = 0;    //counter for the number of times set
int buttonState1 = 0;         // current state of the Increment button
int lastbuttonState1 = 0;     // previous state of the Increment button
int buttonState2=0;           //current state of the button2 (decrement button)
int lastbuttonState2=0;       //previous state of the button2 (decrement button)
int buttonState3 = 0;         // current state of the set button
int lastButtonState3 = 0;     // previous state of the set button
int SHITHOUR;
int SHITMIN;
int SHITSEC;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
char Digitalchar[] = {'0','1', '2','3','4','5', '6','7','8','9'};
char stringHOUR[3];
char stringMIN[2];
char stringSEC[2];
char stringDATE[2];
char stringMONTH[2];
char stringYEAR[2];
DS1307 clock;
void setup() {      //start of void setup
  Wire.begin(14,15);
  // initialize the button pin as a input:
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin2, INPUT);
  pinMode(Setbutton3, INPUT);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // initialize serial communication:
  lcd.begin(16, 2);
  clock.begin();
  SerialUSB.begin();
}      //end of void setup
 void loop() {        //start of voidsetuptime
  // read the pushbutton input pin:
  buttonState1 = digitalRead(buttonPin1);
  buttonState2 = digitalRead(buttonPin2);
  buttonState3 = digitalRead(Setbutton3);
  if (buttonState1 != lastbuttonState1)     // compare the buttonState to its previous state
    if (buttonState1 == HIGH)     // if the current state is HIGH,
      buttonPushCounter++;    // if the state has changed, increment the counter
      lcd.print(buttonPushCounter);
      }    //end of (if (buttonState1 == HIGH))
      lastbuttonState1 = buttonState1;    //save the current state as the last state, for the next time through the loop
  }    //end of(buttonState1 != lastbuttonState1)
if (buttonState2 != lastbuttonState2)
  if (buttonState2 == HIGH)
    buttonPushCounter--;
  }    //end of (if (buttonState2 == HIGH))
  lastbuttonState2 = buttonState2;    //save the current state as the last state, for the next time through the loop
}    //end of (if(buttonState2 != lastbuttonState2))
 else if (buttonState3 != lastButtonState3) {
    if (buttonState3 == HIGH) {
      delay(100);
       if (buttonSetCounter == 0)
     stringHOUR[0] = Digitalchar[buttonPushCounter/10];
     stringHOUR[1] = Digitalchar[buttonPushCounter%10];
  //   stringHOUR[2] = '\n';
     lcd.setCursor(0,0);
     lcd.print(stringHOUR);
     lcd.print(":");
     buttonSetCounter++;
   }    //end of (if buttonSetCounter==0)
     if (buttonSetCounter == 1)
     stringMIN[0] = Digitalchar[buttonPushCounter/10];
     stringMIN[1] = Digitalchar[buttonPushCounter%10];
     lcd.setCursor(3,0);
     lcd.print(stringMIN);
     lcd.print(":");
     buttonSetCounter++;
   }    //end of (if buttonSetCounter==1)
    if (buttonSetCounter == 2)
     stringSEC[0] = Digitalchar[buttonPushCounter/10];
     stringSEC[1] = Digitalchar[buttonPushCounter%10];
     lcd.setCursor(6,0);
     lcd.print(stringSEC);
     buttonSetCounter++;
   }    //end of (if buttonSetCounter==2)
       if (buttonSetCounter == 3)
     stringDATE[0] = Digitalchar[buttonPushCounter/10];
     stringDATE[1] = Digitalchar[buttonPushCounter%10];
     lcd.setCursor(0,1);
     lcd.print(stringDATE);
     lcd.print("/");
     buttonSetCounter++;
   }    //end of (if buttonSetCounter==3)
          if (buttonSetCounter == 4)
     stringMONTH[0] = Digitalchar[buttonPushCounter/10];
     stringMONTH[1] = Digitalchar[buttonPushCounter%10];
     lcd.setCursor(3,0);
     lcd.print(stringMONTH);
     lcd.print("/");
     buttonSetCounter++;
   }    //end of (if buttonSetCounter==4)
          if (buttonSetCounter == 5)
     stringYEAR[0] = Digitalchar[buttonPushCounter/10];
     stringYEAR[1] = Digitalchar[buttonPushCounter%10];
     lcd.setCursor(6,0);
     lcd.print(stringYEAR);
     buttonSetCounter++;
   }    //end of (if buttonSetCounter==5)
   else if (buttonSetCounter == 6)
WRITETIME();
WRITEDATE();
clock.setTime();
DISPLAYTIMENDATE();
   if(buttonSetCounter > 7)
        return;
   }    //end of else if (buttonSetCounter > 3)
   }    //end of if (buttonState3 == HIGH)
   }    //end of if (buttonState3 != lastButtonState3)
   }    //end of void setuptime
    void WRITETIME()
   int hours = (stringHOUR[0]-'1'+1)*10 + (stringHOUR[1]-'1'+1);
   int minutes = (stringMIN[0]-'1'+1)*10 + (stringMIN[1]-'1'+1);
   int seconds = (stringSEC[0]-'1'+1)*10 + (stringSEC[1]-'1'+1);
   clock.fillByHMS(hours ,minutes , seconds);
 }    //end of write time
  void WRITEDATE()
   int dayofmonth = (stringDATE[0]-'1'+1)*10 + (stringDATE[1]-'1'+1);
   int month = (stringMONTH[0]-'1'+1)*10 + (stringMONTH[1]-'1'+1);
   int year = (stringYEAR[0]-'1'+1)*10 + (stringYEAR[1]-'1'+1);
   clock.fillByYMD(year, month, dayofmonth);
 }    //end of write date
 void DISPLAYTIMENDATE()
        lcd.print(clock.hour, DEC);
	lcd.print(":");
	lcd.print(clock.minute, DEC);
	lcd.print(":");
	lcd.print(clock.second, DEC);
        lcd.setCursor(0, 1);    //date is bottom row
        lcd.print(clock.dayOfMonth, DEC);
	lcd.print("/");
	lcd.print(clock.month, DEC);
	lcd.print("/");
	lcd.print(clock.year+2000, DEC);
	lcd.print(" ");
	lcd.print("*");
	switch (clock.dayOfWeek)// Friendly printout the weekday
		case MON:
		  lcd.print("MON");
		case TUE:
		  lcd.print("TUE");
		case WED:
		  lcd.print("WED");
		case THU:
		  lcd.print("THU");
		case FRI:
		  lcd.print("FRI");
		case SAT:
		  lcd.print("SAT");
		case SUN:
		  lcd.print("SUN");
	}    //end of switch case
}     //end of DISPLAYTIME()
If the names reflected the function of the pin, then the comments would not be needed.
int SHITHOUR;
int SHITMIN;
int SHITSEC;
I don't guess it'll ever be Miller time, then.
An array where the ith element is i+'0' seems useless.
char stringMIN[2];
char stringSEC[2];
char stringDATE[2];
char stringYEAR[2];
There is no way to store two characters AND a terminating NULL in two elements. These are, therefore, NOT strings, making the names patently stupid. And, you should NOT be passing these arrays to functions that expect strings. That includes lcd.print().
  SerialUSB.begin();
Which Arduino did you say you were using? Oh, wait, you didn't.
You also failed to describe how the external resistors and switches are wired.
else? Why does the state of switch 3 depend on the state of switch 2?
Your indenting, and lack of white space, sucks.
